That is the question. I am looking at a Sharp LC40D68UT but it seems to not have dot by dot. It does have "Vyper Drive" which turns off all the image processing things as far as I know.
I will be using a HDMI cable to connect to the tv.
Here are the specs: Video
Technology TFT active matrix
LCD backlight technology Wide Color Gamut-CCFL
Resolution 1920 x 1080
Display format 1080p
Refresh rate 120Hz
Image aspect ratio 16:9
Pixel response time 6.0 ms
Widescreen Widescreen
HDCP compatible Yes
TV Tuner
TV tuner presence Yes
Digital TV tuner ATSC,
QAM
Analog TV tuner NTSC
TV tuner reception system QAM,
ATSC,
NTSC
Audio
Speaker(s) 2.0 x Right/left channel speaker - 8.0 Watt
Total output power 16.0 Watt
Audio controls Bass,
Balance,
Treble
Convenience Features
Additional features Optical Picture Control (OPC),
On-screen menu,
Vyper Drive
Connectivity
Video interface Component,
Composite,
HDMI
HDMI ports qty 3.0
PC interface VGA (HD-15)]
Since it doesn't have dot by dot, should I just move on from that tv and keep looking?
Refresh rate 120Hz
HDCP compatible Yes
TV Tuner
QAM
ATSC,
NTSC
Audio
Balance,
Treble
On-screen menu,
Vyper Drive
Connectivity
Composite,
HDMI
HDMI ports qty 3.0
