Originally Posted by
Breyean
I know TVGOS is not even available in most places anymore, but here in AZ it was going strong until a few weeks ago. Then weirdness ensued.
I have quite a few Panasonic recorders in service - some active, others just plugged in but not used too often. I have an EH55, two EH75s, an E95, two E85s and two EH50s that have me scratching my head.
Here's what's going on. In one room, there an EH75. TVGOS working fine.
In another bedroom, the EH50 lost the listings for about a week, then came back this week.
In my office, I have all the units hooked to the same splitter. One E85 is getting listings fine, but the other three machines in here, E95, E85 and EH50, all have nothing. I keep getting the message when I try a setup that the search for listings has failed. Meanwhile, same connection, that other E85 hums happily along.
In my family room the EH55 has had nothing for so long I now get the screen telling me it appears TVGOS is not available in my area and I could disable it to make manual recordings. Meanwhile, same splitter, the EH75 in there had lost listings for a week or so, then this week they came back. The E85 in that room also has had no listings for a couple of weeks.
I have done a hard reset on all the machines, except the one EH50 and the EH75 in the bedroom that still get listings. After that was done, only one E85 and the EH75 in the family room found the signals.
It's driving me nuts. Every morning I look to see if anything has changed but I'm always disappointed. I realize there are two different versions of the TVGOS involved with these models, but that doesn't seem to be it since I have two EH75s working while an EH55 is dead, and one EH50 and one E85 working while others with that version can't get a signal.
I really just wanted to rant a little. I realize I'm on borrowed time with TVGOS anyway, but I sort of expected all the machines to lose it at the same time.
hi breyan...
welcome to the TVGOS nightmare. i, too, have suffered lo these many post digital transition years with my panny e95 Version 7 TVGOS...
1 - are you using a CATV provider ?
if so, fear not, it's most likely the CATV provider path that's screwing up..
i am in Las Vegas, NV. i am using Cox Cable as a provider... originally ( pre digital ), TVGOS was delivered usually via the local PBS stations. the PBS stations also historically provided time signals in the VBI section of their video signal, to allow our whiz-bang VCRs to auto set their clocks ( but that's not important right now ) ...
POST digital-transition, the majority of TVGOS delivery was taken on by the CBS affiliates throughout the country, although some PBS stations still also deliver the data...
in Las Vegas, BOTH the CBS affiliate AND the PBS affiliate are delivering TVGOS data.
the TVGOS data that is delivered comes in 2 different formats, although one cannot get a straight answer out of ANYONE ( been there done that... i've tried )...
the 1st format i'm aware of is the original ' legacy ' data, which feeds listings in the sequence of Day 1, Day 2, Day 5, and Day 8 each day... after a few days, this results in a week's worth of listings that gets continuously updated...
the 2nd format is a ' newer ' format that only seems to provide 3 days of data updated daily...
into the mix, the nightmare is compounded by how the stuff gets to your panny box... my provider ( Cox ), and likely yours as well, has equipment that is network based, and is used to collect the data streams. these streams are then inserted into some analog cable channel, so that our older machines can recover them.
in its infinite wisdom ( NOT ), cox has elected to deliver the newer data stream via the analog cable channel for our local PBS station. cox MAY be delivering on the CBS analog channel as well, but i have not been able to force my machine to lock onto the CBS affiliate, and it always ends up locking onto the PBS channel. while it does work, i only get 3 days worth of listings on my machine that's supposed ot be able to maintain a week's worth, and that drives me crazy....
your panny(s) are getting confused at various times probably because they locked on at different times and, when they lose the feed ( for whatever reason ) the only wait so long before they give up.
ultimately, a complete reset is needed ( a REAL reset - one that makes your clock go back to blinking 12:00 )...
during the transition and in my frustration, i picked up an OTA analog to digital converter box, eg, a DTVPAL set top box, which was one of the ones that was available with the government $40 credit cards... there are a few others, as well... some of these ( like the DTVPAL ) support TVGOS, and will perform the conversion and then deliver it to your panny...
my complicated solution to the dilemma was to mix the DTVPAL's RF output on channel 4 ( in my case ) with my provider's cable tv feed... further, i had to notch out my provider's PBS channel, to keep the panny from trying to lock up on that one, and to favor what got provided by the DTVPAL box.
these set top boxes are, of course, OTA devices and, as such, need to receive stations over the air. in my case, i settled on the local CBS affiliate.
so, the set top box is ONLY used to provide the TVGOS feed from the ' over-the-air ' CBS affiliate. it has no other purpose. in fact, TVGOS support on my box is mutually exclusive from standard OTA reception ( you can't really do both at the same time ). and i rely on my cable provider to deliver my normal cable programming....
in any case, even my complicated setup DOES fail occasionally, and i have to do a full reset to bring things back to life, and it sometimes takes several days for things to stabilize. looking for your updates in the morning may result in the ' Search For Data Has Failed ' for up to several days before your panny finally locks onto its host...
if you do decide to use the DTVPAL, or one of its competitors, make sure it supports TVGOS, as most of them do NOT have this feature...
my DTVPAL box has 2 methodologies for TVGOS support. the first is via what is offered in the owners manual.... that is to use the DTVPAL in TVGOS mode, feed its line outputs into your panny L3 input, and then use the IR blaster from the panny to control the DTVPAL. inclluded in this setup is a directive to utilize a ' bogus ' zip code in the panny... this methodology does work, sort of, but will only provide you with OTA listings using wierd channel numbers. in this mode, the panny will accept your channel request, and will control the DTVPAL to make it tune to whatever channel you want.
if you are using CATV, though, this methodology sucks...
the 2nd methodology is to ignore the owners manual and tell the panny you have CATV with NO box, and use your normal zipcode ( none of this is documented in the owners manual )... you then set up the DTVPAL normally, including scanning all OTA channels and committing them to memory, followed by implementing TVGOS Support Mode in the DTVPAL.
this methodology requires you to mix the RF output of the DTVPAL as i described above ( i chose to use channel 4, and installed the appropriate notch filters and a channel 4 combiner ) ....
sooooo... your panny now receives cable programming on everything but channel 4, which is delivered by the DTVPAL, which is presumably connected to an OTA antenna.... the signal does not need to be fantastic, but it needs to be able to show a reasonably good picture on the CBS affiliate station. this methodology also does NOT utilize the panny L3 inputs, nor do you need the IR blaster setup.
in my case, as stated before, i also had to notch out the Cox Cable channel for the PBS affiliate that provided TVGOS, to avoid having my panny randomly let go of the CBS OTA signal and latch up to the Cable PBS channel.
you may not have this issue, but you might expect it...
if you have some interest in going this elaborate route, i'll be happy to try to help you with some drawings and instructions, as well as where to buy parts from to make it all work.
i've been slowly weening myself away from TVGOS due to the hassle, but i haven't really lost faith yet, since TVGOS in its digital form is hopefully not going away very soon. using the DTVPAL or other supportive competitor box should stave off obsolesence for some time to come, since these boxes DO derive their TVGOS Analog support output from the TVGOS digital signals...
rgds,
ron g
