Yet, there are good belt driven TTs, designed with good isolation and "inertial" stabilized, I wouldn't discount a TT just because it has a belt, unless you are a DJ.
Nor would I. They're really just two ways to solve a problem. Implemented well, either can work.
But IF your primary concern is speed accuracy/constancy, AND IF your budget is in the hundreds rather than the thousands, THEN you will almost surely be happier with a DD unit.
