Originally Posted by doodoobutter
The box isn't too big for me, so I think I'm just going to build it how winisd pro is telling me to. I'm still now sure how to tell if the ports are the right size. Is winisd beta accurate enough on the port noise calculations with multiple ports (vent mach)? If it is, I'll use that instead, because I can't figure out how to use the pro version.
I also need an opinion on the high-pass filter. Do I need one? It has to be cheap, because my budget is going to be thin after I purchase the sub(s). I think I saw some that look like little adapters between the rca and amp input. Are those any good, and what frequency should I be cutting off at, if I even need to at all?
Thanks, I'm pretty sure I won't have any more questions after that
I would suggest using the Pro version, I believe the beta version is not accurate for multiple vent velocity(?). You always need a hpf when using vented or passive radiator type cabinets. The adapters you are referring to are Fmods, and they do a fair job, but the filter frequency varies with input and output impedance. You may fair better either going sealed or getting a plate amp that is hpf ready. There are a couple of amps on PE's Flea Bay site.....I purchased a couple of items there and got the same level of customer service, the items I received were indistinguishable from new, including a RSS390.
