Basic question on how to best broadcast wireless network in new home (under construction) - pretty typical install I would guess.
Question: Basically can I put my main wireless router off of an ethernet outlet on the main floor instead of hooking it into the cable modem in mechanical basement room and still have a single network in the house to stream between? I would use a multiple port switch to make all the other runs hot from the cable modem. This would be to give better range in a 2 story.
Consideration: Would like to have a central network so I can hook up PC upstairs and stream directly down to WDTV in main living room. Would not having wireless router right behind cable modem defeat this idea?
Details:
- new home construction - multiple cat5e jacks all running back to the basement mechanical room as well as main ct5e run from exterior for service hookup.
- Will have a total of 7 cable runs and the run from exterior in the mechanical room.
- Cable modem (comcast) will be installed in mechanical room.
- Would like to try using a netgear (similar) switch to connect the cable modem to and then feed live signal to all the cable runs going to jacks in the house.
- Would just plug router into one of ports on main floor and try to broadcast my wireless network from there.
I would like to have it setup like I do now, where I can stream from PC down to WDTV or from Mac to WDTV and access Mac from PC and vice versa.
I just don't know if putting the wireless router on the main floor instead of connected to cable modem directly would impede this.
Details:
