Originally Posted by
skidog
Will BB let you use the 250 dollars from the free GS calibration and apply it towards having the design center calibrator come out if you pay the difference?
Not really sure. It certainly isn't something that was intended to be part of the offer. There is also not really a way for one system to credit another, as they were not designed to work together. It would essentially require them to just flat out discount their calibration by $250, which seems unlikely.
What it comes down to is, if you qualify for the free calibration, take it. It is very unlikely that you will be worse off than when you started. If you are, call them and tell them you are dissatisfied. They should send someone else out to fix it. Either way, if you don't like the result and still want one of the traveling calibrators to come out and "re-do" it, there is no reason they can't reset the TV or otherwise "fix" it. They are charging enough as it is, they should be happy to come out and show-up the competition.
