I have been looking for tvs to replace my aging analog sets that I use with a converter box that has a guide. Not great but it shows the current and next show on all the channels. I picked up a Sharp DP47840 and found it only gives the info on the current show. So I asked around and Vizio was suggested. I picked up a E220VA and found it only gave info for the currnet show. Before I got it I emailed Vizio about the guide and got this response which I consider very misleading - I don't think info on the current show is a guide and I think most people would agree with me:
Dear Valued Customer,
Thank you for your recent inquiry with VIZIO. I would be more than happy to help you with your concern. Here at VIZIO we do offer best in class technical support.
VIZIO TVs do come with a Guide feature. Unfortunately many broadcasters and cable companies have stopped sending the information the Guide button on the remote displays. It may work sometimes when using an antenna on the digital channels provided but it is still at the discretion of the broadcaster if that information will be sent with the signal.
I apologize for any inconvenience this may cause.
If you need any additional assistance feel free to contact VIZIO at 1-888-849-4623 or chat with us at chat.vizio.com
Thanks and have a great day!
I also contacted Sanyo about a guide. They at least were honest about it and said:
Unfortunately we dont have a TV set with EPG built in except for the DP32649 model that TV set has TVguide built in, but that would be a discontinued model which we stopped manufacturing at the end of 2009.
Thank you have good day,
SANYO Support.
Seems like a few years ago TVs had this but no longer...
SANYO Support.
Besides, signal meters can be misleading depending on what they display (signal "strength" and/or dB readings).
