AVS › AVS Forum › Display Devices › CRT Projectors › Proxima desktop projector 6850+
post #1 of 3
Hi everyone, I have a proxima dp 6850+ that I've received as a gift from my parents. It seems like its been used for about a year or two. It works perfectly fine and it's in great condition, They said it was worth about close to $9,000 brand new. I dont think I have a used for it. So Im wondering how much can I get for this projector? and what is the street price on this...I would appreciate if anybody on here can help me out. Thanks!
post #2 of 3
Congrats on getting a projector. You should probably know though that this is the CRT Projector forum - your projector is LCD (uses a transparent screen like a flat screen TV). Considering the age and listings on Ebay, $50-100 would seem reasonable for a local offer. Prices on these things change rapidly as the materials inside are constantly being updated. You might do better just to try out using it yourself, but check out the LCD forums though for a second opinion.
LCD Projector forum here:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=68
Sell on AV Forums here:
http://www.avsforum.com/avs-vb/vbclassified.php
And try VideoGon for reaching serious home theater junkies:
http://www.videogon.com/
post #3 of 3
sell it on ebay if it works. Its problably worth about 200.00 300.00 on a good day.
Proxima projectos are more for commercial use then home theater. Thats an old projecter for commerical / use.
  Back to Forum: CRT Projectors
