AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung UN60ES7500 & PN60E8000 Turns off and on Every 10-15 Mins
post #1 of 9
I am having a issue with my Samsung television turning off and on every 10-15 mins. I am really asking for help as I have been spending countless hours on this and did every possible troubleshooting on this. I first bought and return 2 plasma Samsung PN60E8000 which would turn off and on every 10-15 mins when I am watching TV. I then just switched to a Samsung UN60ES7500 and it is still happening the TV shuts off and on every 15 mins when I have it on. So I am on my 3rd TV and it is still giving me issues.
I have tried different sources, different hdmi cables, different power outlets, different Directv boxes hooked up to it. I have tried everything I can think of and also I am working with some audio guys that are certified Samsung techs and they couldn't figure out the cause of this happening.
Has anyone heard of anything like this happening? Is there anything I should do or should I call geek squad or just return it to best buy again. I am paying these audio guys to set up the TV and I don't want them to do it a fourth time. I am really frustrated and at this point I just want a working TV. Any help or comments is appreciated.
post #2 of 9
It's been happening with the es8000s, check out the owners thread. No solution yet.
post #3 of 9
A week ago I had a new UN46E6500 delivered to my place, and after some setup, firmware and the like, it started to do the "power down and then start up again" every 10-15 minutes.
I troubleshooted and worked with Samsung tech Support via chat. Samsung said service was needed on the TV (was not in my place more than 10 hours).
A 2nd unit was delivered Thurs. and again after setup and firmware, it is doing the same thing.
Not a happy camper.
post #4 of 9
Not a happy camper.
Finally worked out with BestBuy to get the UN46D6900 instead. No problems with that at all.
PDH
post #5 of 9
Me too! New ES7500 turning on and off every 5 minutes or so. They replaced it with a new TV and now it is doing the same thing. Any suggestions on what to do? Is this is factory defect?
post #6 of 9
My first es8000 turned off every 5 minutes they changed it
The second one is doing the same after 4 days working properly.
This definetely a Major factory defect, what do we do?
Samsung we need an answer
post #7 of 9
I had the same problem where it turned off and on every seven minutes.
I fixed this by resetting smart hub to its defaults, and resetting the TV to its defaults, done by opening the menu and navigating to the right location. The smarthub reset was probably unnecessary, but I had nothing to lose.
After the reset of the TV, my TV has worked fine.
Hope this helps.
post #8 of 9
It's been happening with the es8000s, check out the owners thread. No solution yet. 51.jpg
post #9 of 9
The "off then on" problem seems to occur in many different Samsung models inculding my week-old lcd 60" 8000 series. But Samsung continues to sell this crap. If you were unfortunate enough to buy one of these gems, there's only one solution; take the damn thing back and avoid another Samsung. Fortunately for me, i'm still in the Best Buy 30-day return window. Others may find themselves in the unfortunate position of the samsung warranty which may involve a service tech not observing the problem and therefore not being repaired. Better yet, your TV could be sent out for a few weeks to a repair center. Ever get anything back from a repair center after a major repair? Fun. And you spent how much for this experience? If you're really lucky, you can experience this apparantly well-known defect while out of warranty. Good luck with that, sucker! In my opinion, Samsung sucks!
