AVS › AVS Forum › Audio › Speakers › quick question on pioneer fs51s and lepai amp
post #1 of 8
i got a set of pioneer fs51s and looking for a cheap but good little amp to power them. i want to use the speakers for computer speakers and for ipod only.
could this little lepai amp power them?
http://www.amazon.com/gp/product/B00...A385A0XNQBW8HY
post #2 of 8
IIRC, that amp has been recommended for the Pioneers before.
post #3 of 8
just my 2 cents,the lepai amp is a great little amp.i just purchased my 2nd one to use with a used pair of wharfedale 7.1 speakers for my work.for approx. $45 i have a great sounding at work system i also have one in my garage hooked up to some older venturi towers and a mp3 player in my work area and it sounds great it also gets loudfor such a smallbox and stays cool even after 10 hours of use.like i said for the watts it gives at 8 ohms it does get loud.but if you turn it all the way up it gets a little distroted and sometimes clips and shuts down,but all you do is turn the volume down abit and it turns back on.i also found out the better the recordingthe better the sound for example i down loaded most of my music from cds andthe sound is top notch compared to music downloaded from itunes. for the price there is nothing out there that can beat this little amp.its simply blows my mind.again just my 2 cents
post #4 of 8
I never knew that amp's where that inexpensive.
post #5 of 8
I have two of the Lepai 2020+ amps. Great for connecting passive speakers to a computer, ipod or portable device. Only 10W channel but great for $25.
post #6 of 8
I would look at other options before buying. While the amp may be great for what it is, however, if you are like me, then you would have to go through 3 different units until you got one that worked right. They sure are inexpensive though.
post #7 of 8
67jason I did read some reviews on amazon about people going through a few defective lepai amps. I see what you mean.
post #8 of 8
good thing amazon has a hassle free return policy
  Back to Forum: Speakers
