Ok i just experimenting and trying to make a recording to VHS on my EZ48V.
My LCD TV has audio and composite out put. I fed these into the front AV input on the EZ48. I had the EZ48 rear out put connected to my other CRT via composite just to see what was happening. It passes through colour picture through EZ48 to the CRT fine. I went and pressed record and recorded to VHS for a few minutes. After that when i played it back on the TV it was in black and white. I though oh no why would it not record to VHS in colour?
Then i disconnected the CRT and fed the composite output from the EZ48 direct to my LCD TV. Same thing, black and white. What was recorded on the VHS was black and white. So then i thought it was something to do with the AV out on my LCD TV.
Next thing i did was set up a separte set top box and connect that directly to the front AV input. Made a recording and the same thing happend and it recorded to the VHS in black and white.
So i have proved its the EZ48V, at least the front input. I have not tried the rear.
Why can i only record in black and white to VHS?
I feel like i have been through all the settings, switched between NTSC/PAL etc.
The only thing i am not sure of is what does setting the comb filter on/off do?
I hope its not a problem with my unit, have not even filled out warrenty card yet, so this problem is now top priority for me.
Any idea why it wont record in colour via front AV input to VHS? Is the EZ48 even ment to have this capability or are the AV inputs only for recording to DVD?
Ok i just checked and i can record in colour to VHS when using the RF in/inbuilt tuner in the EZ48.
So that proves its not a tape problem.
