AVS › AVS Forum › HDTV › Local HDTV Info and Reception › WTTW Evolution lip synch problem
post #1 of 3
Anyone else? Using Dish 6000.
post #2 of 3
Same here. Also, the only way I get a 1080i signal is to manually tune my DST-3000 to 47-1 which remaps to 11-1. Going directly to 11-1 looks analog and 11-2 looks to be 480i. Also, the HD signal drops back to 480i after a short time.
post #3 of 3
Same problems as above Over the air on 11-1.
It seemed to get resolved later in the program.
(WTTW Experimenting again?)
This thread is locked
