i am lost...
i also feel i have made a lot of mistake in my choices in a/v
(so help if you can... and try not to laugh)
here is what i have..
a sony str-ga8es with tannoy 607's
a separate v25 bose system (5.1) hooked up to my tv..
this is what i noticed
my ga8es does not have optical or hdmi (bought in 97 i think ) but has 5.1 (in different colour codes in the back)
what i hate about mp3 (after i downloaded all this music that i cannot buy here in canada) is that there is no quality in sound period.
so i started downloading in flac's and am more happier now that before..
so i decided to connect my pc to my receiver using a 'y' cable from my pc to my receiver input is 'cd' i tried aux but id did not work....
here is my issues. i asked a few friends but everyone seems to be guessing ...
a) when i play my music i feel its lacking power...
its missing that thump.. that beat..
does this mean i need a more powerfull amp?
or is it because i need a sub?
is this because i need to buy a dac? (dont even know what it does (yeah i tried reading but it goes over my head). but the dac at a store sounded much better....
b) should i buy a pre amp? and hook it up to my integrated amp? can this be done? if so how?
c) someone at a store told me since i dont have hdmi or optical on my receiver i will never get 5.1 surround sound... unless i bought a ac3 decoder and used the 5.1 inputs at the back of my receiver....
is this true?
d) my bose system is 5.1 and i have tried playing a cd and changing it from 5.1 to a 2.0 but it really lacks power.. my assumption is because its built for 5.1 and not audio...
e) on the str-ga8es it has button called "direct pass" what does this mean and what is it truly used for ?
what the heck am i passing and from where am i passing it from?
f) using just one amp with the tannoys since it has the capability for bi wiriing am i getting the best of it? or what would your recommendations be to make the most of it...
g) am i nuts?
h) pdf.crse.com/manuals/3856160111.pdf
is this true?
g) am i nuts?
-- for a total of 100-300 Watts on the average: less than 5 Amps.
