Originally Posted by raghump
Thank you for the picture and information. Unfortunately the room is above the garage and the ceiling has no room above it as the roof is over there. So fishing the wires or hiding the power brick above the ceiling are ruled out. I might just have to find an elegant solution to keep the power brick visible below the ceiling itself. Anyone done something like this and provide some ideas?
Yeah, I'm used to velcro, I use it to attach the remotes on my tv's the back of unit, and I use it for all types of stuff. You might have to put 2 or 3 strips of velcro to back of power supply and press it next to ceiling mount or somewhere else that would look good, and do as the other guy just wrote, get an elegant extension cord, in white or color that would work for you. I even used velcro to attach powersupply of my ion htpc to the back of my 32 inch tv , so I do use it for all types of stuff. Maybe tie cords would work too, I use them too, and zip lock it in place with 3 or 4 zip ties. The zip ties would be more permanent solution compared to velcro, so you got choices. I like having the LG 70G free, so I can put it anyplace, but I'm like that with my bulb PJ too. But ceiling mount is cool too, take pictures of finished placement.
. A quick wipe with a camera safe lens cloth and my focus is now nearly equal corner to corner.
