On one of the old Acer K330 Led projector threads where we were talking about the heating problems and the the focus problems with the heating problem I wondered if the guts of the Acer K330 projector, the LEDS, cooling heat sinks, the power supply would fit into a old bulb based projector where you would plenty of room for the projector to breath.
One day I looked at the parts of the INFOCUS X2 projector on Ebay and wondered if it can be retro fitted on these LED projectors ?
Would the physics of these lens of the older projectors work with these DLP LED projectors ?
To bad these LG PA70 G projectors are relatively new since there are no used parts for these projectors either on Ebay or the internet to buy and experiment with.
ktury jest bardzo dobrze znany i rozumiany np w instrukcjach.
