AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › LG PA70G LED 1280x800 700 Lumens.
LG PA70G LED 1280x800 700 Lumens. - Page 66
post #1951 of 2305
corpkid12, I have mine set up just as you described, ps3,directv going to my avr via HDMI (which has pass through) to my LG pa70g and everything looks great I set my ps3 and directv box to 720p and it seems to be slightly better overall pic. probably because the projector is not up scaling everything. as you can see from the pics I posted the picture is very clear and the image looks better then those pics in person. hope this helps.
post #1952 of 2305
Hi All,
Could you please post a link for right 3D glasses . There are a lot of type 3D glasses.
post #1953 of 2305
Originally Posted by sergiobjk View Post
Hi All,
I just ordered these this week and they should work, they are DLP-link glasses from monoprice.com. here is a link to them not 100% sure they will work ,but I am giving them a try plus I can always return them. http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10909&cs_id=1090903&p_id=9459&seq=1&format=2 I think any dlp-link glasses will work that have active shutter feature. hope this helps
post #1954 of 2305
Hi,
Could you please post a link for right glasses . There are a lot of type glasses.
Thank you.
http://www.ebay.com/itm/Brand-Universal-Active-Shutter-3D-Glasses-for-3D-DLP-LINK-Ready-Projector-/121001808309?pt=US_3D_TV_Glasses_Accessories&hash=item1c2c4511b5
This one works great. Cheap, light weight, Long battery life. I have it since Christmas and charged only once. Perfect for the price, and fast shipping with tracking number. (Not usual from China sellers).
post #1955 of 2305
i use thoses ...
http://www.amazon.com/Lumsing-Rechargeable-Compatible-Mitsubishi-Projectors/dp/B00B8NW6G4/ref=rec_dp_3
they do the jobs .. for watching 3 movie/years .... smile.gif
post #1956 of 2305
So, looking at the manual if you have a 3D BD player you can watch 3D movies as long as you have the 3D DLP glasses?
Am I reading that right that all I need to watch 3D is a 3D player and glasses?
post #1957 of 2305
No, you cannot use a 3D blu ray player, only a PC @ 120Hz can be used to obtain 3D with the PA70G at this time (the conversion boxes do not work either from what has been reported).
Jason
post #1958 of 2305
Someone mentioned the Best Buy Exclusive LG PA75u. Is the only difference between the PA75u and the PA70g that the PA75u has an antenna/coaxial cable input? Ignoring the Best Buy exclusivity, is it worth it? I am a recent cable cutter, and use Roku 3, PC, and over-the-air HD channels. I also have subscriptions to Hulu Plus and Netflix.
post #1959 of 2305
Looks to be the same except for the built in tuner. If you already have an OTA tuner you may want to go with frys when they come on sale for 499.00.
Bohanna
post #1960 of 2305
Thanks, your pics look pretty good and 106" is about the size I was thinking of going with. What type of screen are you using?
-Jay
post #1961 of 2305
-Jay
thanks like I said though the pics I posted don't do the real thing justice they look a lot better in person. the screen I am using is from best buy made by Projecta - Model B 106" Pull-Down Projector Screen - White it's $199 it work very well I think and easy to put up.
post #1962 of 2305
I have one projector already mitsubishi hc3800 1080 and I very happy with it but I want one for different use .
I want to use for any moment than I want to see a big picture and I want to ask .
if the picture is enough for make me happy or put me nervous for a bad buy when i compare with the other projector.
I'm know than the first with lamp is better picture for sure but I want to know if the lg is watchable.
Fears
Picture to dim over any other
The resolution with the diamond pixel
Is so bad the focus problem?
Is one advantage the wide led color gamut or not noticeable or transform in problem
I do not want the best picture i want a big 100" enjoyable picture.
Cheers
post #1963 of 2305
Fears
Cheers
If you are like me, and wanted a cheap LED PJ (399 at fry's) with 30,000 hours of use on it without bulb replacement, small and portable and the highest lumens of the 720p crowd, of 700 lumens, this works. Now, you have to have DARK ROOM to enjoy it, and you have to exchange unit if you get unfocused one (although I think your chances of getting a focused unit is better than 6 months ago), and it is slightly short throw. 8 feet back is 80 inchs, 10 feet back is 100 inch screen size.
It comes with 2 year warranty in USA, and some of the other clones that are 500 lumens have start up focus issues but this model doesn't have that problem. Also, this model has 6 watts of stereo internal sound which is kick ass (easily fills small room), and good contrast ratio of 15,000:1.
I got it for easy on and off anytime, good for gaming (low lag), I don't notice any RBE.
The built in media center is EXCELLENT (avi's, pdf's, txt, mp3' 99 percent of everything I throw at it works when I put it on usb memory stick.
In a way, this pa70g is good for casual use and when you want to bring out the BIG GUNS for special viewing take out the BULB PJ.
Look at Redneck Geeks 41 min youtube review and degamepimp's pictures in this thread and also he has Youtube videos, so you can get a feel for it.
Don't get it for 3D as main PJ, but it does work with PC that can play 3D stuff, but, if you are into regular 3D viewing get something else but ok for once in blue moon.
post #1964 of 2305
a few pages back on this thread someone posted that they were in a fry's store that had the lg pa70g and a lamp based projector in it (darken room that is) and they stated they could not see a difference in the two playing the same thing on different screens. the lamp projector was about 3 times the $$ and the lumens on the lamp one was 2-3000 lumens (I will see if I can find the page). I watch movies,,sports ect.. on my in my basement and love it. just saying biggrin.gif
post #1965 of 2305
Yeah, if the room is DARK, I don't see too much of a difference between my bulb (2,000lumens) and LG PAG PJ (700lumens) . But if there is light in the room, the LG can get washed out whereas the Bulb based PJ will still look good. The good contrast ratio on the LG gives good color and vibrant.
Another use for the LG is just as 30-40 inch tiny screen use, like hdtv and can use in any room, any wall, and play audio books, or read pdf's. (since it's self contained you don't need anything other than the pa70g with memory stick whereas with other PJ's you need PC or other device hooked up to it.) Or point at ceiling, lying in bed or floor. Since it's so small a PJ, about size of netbook, with easy on and off, you can use it for multipurpose stuff. You can use it during the daytime on small screen sizes of 30/40/50 inchs. And with 30,000 hours life, it's like a hdtv.
post #1966 of 2305
I just bought a Panoview Grey Wolf II Manual 92" off Craiglist for $125.00, will this be a good screen for the pa70g?
post #1967 of 2305
Other thing I forget to ask
What about of the shadow detail I m very picky with in this matter ,
in the dark scenes yo see detail or lose a lot
In the typical scene of train in casino royal
Or may be in the new skyfall in the introduction scene in the passage.
post #1968 of 2305
Fears
Cheers
If you are expecting the PA70G to match the HC3800 (which I have owned as well) you'll be disappointed on most counts.
However this does not mean that if you obtain a solid PA70G that it will fail to impress you over-all.
Here is a link to a 1080p video that I made when I had the PA70G... http://youtu.be/mWhYQNV0mw4
Sorry frown.gif but that is not a good choice for the PA70G.
It will improve black level and help with ambient room light but the PA70G is not really a bright enough unit for a 92" grey screen IMHO.
Aside from that the Grey Wolf screens have some of the worst sheen (sparklies) of any screen out there (rivaling the Inland screens). I had one for a few days and returned it for that exact reason, it was too distracting and made whites and bright colors look dirty.
Jason
Edited by DaGamePimp - 3/28/13 at 5:07pm
post #1969 of 2305
Sorry for double post but figured this might be of interest for some and deserve the bump...
PA70G on closeout at Fry's for $449.
Jason
post #1970 of 2305
Thinking of swapping my Pany ST30 with one of these; how does BR look on this projector or other similar 720P LED projectors? I've seen most of the photos posted and they all look great to my untrained eye, but i'm just wondering for my own education and situation. Right now I have two viewing locations: one at 8' and the other at 20'. The wall i'd be using is 11' tall and about 20' wide so i'd like the largest image possible, which is 110" or so right?
post #1971 of 2305
it depends on how light controlled the room is. if it's a basement or a room you can get nearly all dark you could go probably up to 150" it just depends on how dark you can get it and how far away you can put the projector. my basement has two window at both ends I cover the one closest to my projector and I have mine projected on 106" screen. I could go bigger ,but this is big enough for me and my seating distance. can't beat it for the price and image quality at this size and i'm comparing mine to my 57" crt rear projection and 51" plasma and this projector is right with them as far as pic. good luck and enjoy.
post #1972 of 2305
Jason
post #1973 of 2305
Originally Posted by Pawel Dubiel View Post
Hello! Gentlemen is the way, the sound in DTS during playback of movies, via mediaplayer.
Normally when watching movies with DTS sound, showing up information, "Sound is not supported", looking through the instructions of the projector, and had the table codecs, I was thinking one thing.
The table in DTS is a description of the "only in Korea".
biggrin.gif no, and here you have, smile.gif HDD plugged in with the film in DTS via remote service, have changed the region code on the 01, that is, KOREA, and surprise, PA70G can now play movies with sound DTS.
Originally Posted by espetodesardina View Post
Hi Pawel, is possible remote service in PB60G? The table in DTS is a description of the "only in Korea" on PB60G manual user too.
Have you found a method to play movie with sound DTS? Do you think it could work also for the LG PB60G?
I would be able to do that with this remote?
http://www.replacementremotes.com/store/images/105201m1.jpg
Edited by otto88 - 3/29/13 at 7:40pm
post #1974 of 2305
I was at my local fry's today and I discovered they have another new model from LG, PB63U guess that's the upgraded version of the PB61U which was discontinued, price is 540.00:D
post #1975 of 2305
Keep the Pany for daytime viewing and use the projector for nighttime and Home theater type viewing. The projector will NOT give you anywhere near as crisp an image as the Plasma will. If you are thinking that you will be able to see the Projector screen "jump out" at you during the day like the plasma, you are wrong and will be sadly disappointed.
Bohanna.
post #1976 of 2305
Bohanna.
I would agree with you. Keeping a good daytime hdtv for regular viewing and using a PJ for night use or movie night/game night is how I think about PJ'S. Don't get us wrong, the big screen is awesome but giving up a hdtv in exchange for PJ wouldn't work for me. I don't mine living in the "darkness" a few hours during the day, but making a steady diet of it is too depressing for me. smile.gif
post #1977 of 2305
Push the " IN START" button and digit acces password "0413" next push the right arow en enter in sub menu for chenging the region code. Sorry it is my english not google translate biggrin.gif
Pa70g and Pb60g dont change nothing, i cant change my Pa70g in Pb60g with this remote control and works. I dont se diferents! But do not want us in this condition my pj, but pa70g its bigger and cooling system its diferent.
If you change the region for corea you can play films whit dts sounds. Its confirmed i traied and works grate.
If my english its understanding a can write in italien languidge. It's tu closer for translate, i dont studing english languige. I know only from films whit PL lektor.
It is only one problem ! If you changing region code for corea you can select only english or corean languidge in menu dont haw more european translations in menu, in evry time you can return in european code region whit european translation on menu but whitout dts suport .
Edited by Pawel Dubiel - 3/30/13 at 4:08pm
post #1978 of 2305
Don't worry, I've understood and... I'm italian! baabidy buppi! Babidy Boopity! biggrin.gif
Edited by otto88 - 3/30/13 at 4:05pm
post #1979 of 2305
Agreed a TV/projector combo is working great for my family. We have the TV located in the bright living room, and then the PA70G in the light controlled basement. Best of both worlds and provides flexibility. Athough there is a lot of juggling for projector time - it gets used now more than the TV. Between Xbox games, videos and web usage - I end up fighting my kids for projector time to watch movies. The reasonable cost and LED light source seems a good match if kids will used the projector a lot, and other than the light control requirements, it functions mostly like a second very large TV.
post #1980 of 2305
For the kids its an absolute NO brainer. HUGE screen in a Mancave vrs Mom and dad with them and telling them to quiet down in the living room. Doesn't matter how crisp the Flat screen is. The bigger than life projector screen would still win even if it was a 640x480 image.
Bohanna
