Wow, sorry to hear it. You must really be sensitive to RBE. I don't see it at all.
post #571 of 2157
10/11/12 at 2:49am
I think the PA70G still makes for some media too much noise when on highest lumen setting, mainly when watching quiet films. So for those quiet films, I use the medium lumen setting, which is still bright enough but much less noise.
, I played with my PA70Gs screws yesterday again and I have 99% good focus, just at the middle of the screen I cannot see pixels grid line as good as at all 4 corners, but its not visible for > 1m distance.
and pass it along to the next person
. I teach, and tend to be wordy when explaining things. Hope it doesn't bore you and others. Thanks.
And this time, it was well spent. Most of all, MY WIFE APPROVED!
V
I am assuming that pa70g stay focused even after you put the case back. I also noticed that flexing the lens case just a little causes focus change. But I had to work with the screws to make the changes permanent. I guess yours just required a bit of "nudge" or release some tension somewhere near the lens case, and removing the case was enough to fix everything. I'm very happy for you
. Enjoy!
