Originally Posted by IP-Man
My opinion is that LG have much to learn before they catch up with companies like Acer/Optoma/ViewSonic in projectors field. When I returned PA70G in store for replacement with a new Acer seller told me: nobody can produce ovens, TVs, washing machines and projectors simultaneously
First thing first:
1. The clones Acer K330 have definitely a defective design, because they lead the heat over the lens, and the blue led has only passive cooling and it is not long live. LG doesn't.
2. Acer suffers from HDMI issue. LG doesn't.
3. Acer media player, speaker and remote capability are very poor. LG plays almost everything and has good features.
4. Acer remote control is poor. LG has full remote.
5. Acer is not support 1280*768@120hz 3D. LG has proper 1280*768/720p@120hz 3D through VGA.
6. Acer suffers focus issue, and user can not fix it only with lens replacement. LG focus issue is user fixable.
7. Lumens output of Acer is weak, user can easily recognize this weakness in 3D at 100". LG has almost acceptable brightness at 100" in 3D.
8. Acer can not change L/R in 3D on remote. LG can.
9. Acer fan noise is very loud even economy setting. LG doesn't.
10. Acer easily suffers from dust blobs. At the moment there is no such information about LG.
LG attained different level of multimedia and entertainment system than clones and other cheap HD Led projectors, with virtual surround, high lumen, noise reduction, edge enhancer, affordable price and good 3D capability.
Edited by tataniko - 12/8/12 at 11:01am
so I guess if you get one from NOVEMBER you are ok. Has anyone tried contacting LG about fixing their uneven focus issue? I sent them an email a couple weeks ago and never heard back from them...
:D:D
