Hi All,
So here's the thing, a friend of mine works at a furniture store and got me a deal on a Sharp LC-60LE630U. I went into the store and checked it out. I thought it looked like a decent LED TV, the settings they used in the store made it look a bit washed out, but I figured I'd get home and calibrate it and it would look amazing.
So I get it home and start making adjustments, but the menu system is extremely lacking in options. I figure "no problem, I'll go into the service menu" however after much googling, I can find very little info on this particular model whatsoever and even if I figured out how to get into the service menu, there is nothing anywhere about what the optimal settings would be from there. I upgraded the firmware on the unit in hopes of gaining some more options in the user menu, but no dice there.
I would appreciate any help that anyone here can offer.
Thanks in advance!!
Thanks in advance!!
