Inspired by paulspencer's fine work on his: DIY Synergy horn I set out to try and build one with drivers I had on hand for as cheap as I could.
You may have seen my post in his thread about a <$25 synergy horn, it will turn out to cost a little bit more then that.
The build begins, I liked the symmetrical appearance of the square 60x60 horn so that is what I chose to use.
The mid drivers are the $0.69 sony buyouts from PE, I have alot of those.
Here you can see me laying out the first panel with driver mounting position and the ports.
Three drawn out on a single 2'x4' sheet of 1/2" mdf
I tried a bunch of angles on scrap untill I got it right and cut my first three, they look like they fit together just fine.
All four cut and held together with some masking tape.
First look into the horn, an MTM bookshelf that holds 5.25" woofers for size reference.
Who got their fingerprints all over my horn.
