Originally Posted by FOH
Don't intend to get OT here, because I really dig what you've done here,....just very cool. Jumping in head first and experimenting like this is just fantastic. Thanks for sharing and continued good luck.
Regarding the audible effect, I'm not so sure it's a Doppler related effect. In my opinion, both the physics involved and the sound I heard lead me to believe it's merely a spectral change. I believe it sounds more related to a significant variance resulting the difference off the axial response, spectrally changing as the mic exits the central part of the radiation, and begins coming across the off axis energy.
Just my opinion on what I'm hearing, you guys may be referring to another sound altogether.
Cool stuff.
I'm curious about the harshness you're reporting. Will you elaborate a bit....? Was it level dependent, or did it exist even at modest output levels? Any more ideas on the cause?
Cool stuff.
Thanks FOH, and I don't think your going off topic.
After just after doing some measurements off axis I know your right that moving off axis and a change in the spectral response is the most likely cause for what is heard in the video.
Here are some off axis axis mesurements 0-15-30-40.
The mids look pretty good but the tweeter response is all over the place
.I wonder if somthing like a phase shield would help there.
The harshness is most likely as I said before from running the tweeter and a very cheap one at that, which I didn't think sounded that great in the first place (sounds better in the horn actually) well below its FS and from it "ringing" at the FS. I still haven't given it a thorough listen, I may do that tomorrow and give a better description when I go though all my usual speaker test tracks.
#2: No modeling, winISD for port lengths into the rear chamber, a little math to cut the horn, and a few minutes in PCD for the crossover design, I just got lucky with it. It did truly sound like crap at first before the modifications. I have quite a few other enclosures/horns that I made without any modeling that did not turn out well at all. You can see one of them on the floor in the picture of the finished horn after the close up of the tweeter. My bose cube tractrix horn, I found out you can't horn load a 2.5" fullrange and expect good high frequency extension from it, good midrange though.
