Just a bit OT:
I was just thinking about the idea of stacking these styles of speaker to produce essentially a horn line array.
Stacking synergy horns would smooth response and present a larger vertical wave front but would defeat the point of building a synergy horn in the first place wouldn't it?
Just reading over the synergy horn spiel and it mentions stacking the synergy horn which maintains a coherent wave front. But isn't the largest advantage of the synergy horn that it acts as a point source? And thus would suffer the normal defects of line arrays with a large C-C distance between horn centers?
Your response is looking great btw!
How big would the horn have to get to horn load/control directivity at 100Hz? From what I remember your 10" woofers would be acting a lot like direct radiators at this size wouldn't they?
... thanks for sharing, best of luck.
I think it would be cool to see how each of these groups behaves individually in your enclosure.
, what a mess.
