AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Help with RS-232 and Cat5
post #1 of 3
Hi Guys,
I have a Panasonic AE7000U with unterminated Cat5 running from it to my rack. I'm trying to use an ITach to Serial adapter to control the projector via RS-232 with the roomie remote.
How do I terminate both ends from cat5e to serial plug. I've read about DB-9 to RJ45 connectors but they all come "unpin". I really don't know how to do the pin out or should I do it another way?
Gear mentioned in this thread:
post #2 of 3
anyone?????
post #3 of 3
1) You definitely want RJ45-DB9 adapters. Something like this one
2) The pinout depends on each device. Most devices can use the Null Modem without handshaking cable shown here
  Back to Forum: Remote Control Area
