AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Wireless 3D TX/RX for LG flat panel
post #1 of 3
I want to mount my LG 55LM7600 on the wall and I don't want to run HDMI cables to it. Is there a 3D equivalent to the LG ANWL100W Wireless 1080p Media Kit? I want a wireless transmitter that will take at least two HDMI inputs (one for my 3D Blu-ray player and one for my HR24 DVR) and transmit them either RF or WiFi to a receiver that is mounted BEHIND the flat panel. I want a clean look with the TV and I do not want to see the wireless receiver. The closest kit I've seen is one from IOGEAR, but the receiver has to be visible for an IR signal for it to function. Any ideas on a manufacturer who has a two-in HDMI transmitter/receiver that is RF or WiFi? Is LG going to make something wireless for their 3D sets?
post #2 of 3
I bought this for the 55lm760 (euro model):
http://www.amazon.de/Wireless-Transm.../dp/B004U2GL52
It has 4 inputs and 2 outputs (one is the wireless transmitter). It works with frame packed 3d from both my htpc and the ps3. This WHDI compliant (sorry for the german link) and is therefore virtually lag free (1-2 ms).
Its a build a little flimsy (very light - all plastic), but it works - Even tried it through one wall. You should be good with 15m line of sight or 5m through a wall. For everything below 1080p60hz its perfect. At 1080p60 I saw some artefacts when trying to go further than 6-7m through a wall (on high frequency test patterns only - not perceptable in real world content).
post #3 of 3
thanks.
I'll check it out.
  Back to Forum: Home A/V Distribution
