AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic TH-58PZ700U - No Video Signal - Full Green Bars on Some Inputs
post #1 of 4
Hello,
I am in need of some direction. I have a Panasonic Plasma (TH-58PZ700U) that's not accepting video input after a thunderstorm.
The Composite AV inputs will show green bars (sometimes horizontal, sometimes vertical (see attached picture)) or black with white spots. Regardless of a device being connected.
All other inputs show no signal
The OSD's work fine.
The H board has already been tested with a spare. It made no difference.
I think one of the D* boards needs to be replaced. I would guess the DG, but I'm not sure.
Am I on the right track? Which board is most likely the culprit?
Thanks in advance!
post #2 of 4
post #3 of 4
post #4 of 4
I have the same problem.Did you ever figure out the correct fix. Thanks
