My neighbor purchased $900 worth of acoustic panels and bass traps. When he moved into our neighborhood, he did not need all of them for his living room. He had 10 acoustic panels and 4 bass traps in his garage that were being unused. He sold them to me for $15 each so I jumped on it.
I brought them home the other night and immediately noticed a huge difference in clarity and detail in my setup. You can read about it in my build thread.
Here are what the panels look like
Here are what the bass traps look like
Below were my initial thoughts of where I might place them.
I ended up temporarily placing the panels (leaning them against the wall) as I sketched out in the above diagrams with the following exceptions:
I did not place Bass Traps in the top right and left corners (will need to make a shelf for that).
I put 1 Acoustic Panel behind the Projection Screen
I did not place two Panels on the Rear Side Walls
I only placed one Panel on the Back Wall.
Other than that, everything else was placed exactly as I had originally planned.
Before just arbitrarily placing the panels in the room where I think they should go, I thought I would seek advice from the experts. The only thing I'm pretty sure of is that I need panels at the First Reflection Points and I have used a tall mirror to determine where those locations are.
My room is 13' x 19' with 10' ceilings.
Any advice you can provide would be appreciated.
