AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Anyone w/experience with Sound Shark 6mm Flooring Underlayment?
post #1 of 4
I'm going to lay down some natural bamboo flooring (not engineered) in an upstairs bedroom. My home theater is downstairs, under this room.
Is this a decent underlayment? The price is a bit more than I want to spend, but with $7 shipping per 100 sq.ft. it's not horrible.
http://www.amazon.com/Sound-Shark-En.../dp/B006TJNDV4
post #2 of 4
That's certainly not cheap.
When you say "not engineered", you're going to nail this down?
post #3 of 4
Hi Ted,
It's the least expensive 5mm or 6mm rubber underlayment I can find. Rubber Underlayment is what I've decided on after researching cork vs. rubber underlayments. I'm still open to other suggestions though.
I will be doing either floating floor or glue down floor. I will not be nailing or screwing down the flooring.
The bamboo is real bamboo flooring. It's not engineered or fake.
post #4 of 4
OK. Floating a floor on rubber is fine to cut impact noise. I'll send you a PM
