I picked up a pool table light this past weekend, and I want to try to get it mounted this coming weekend.
I have a drop ceiling in the pool table area - so I'm looking for some tips from anyone that may have done this before.
I was going to get one of these to put an outlet in the ceiling to plug the light into:
- so I have that part covered.
The question I have is how do I go about mounting the light itself? I've seen suggestions that range from spanning a piece of wood across a tile and putting a hook into it to hanging a hook from a wire that goes into the wood up above the drop ceiling. I'm just looking for the "best" option.
This is the light I picked up - it is all metal, so it has a bit of weight to it:
- so I have that part covered.The question I have is how do I go about mounting the light itself? I've seen suggestions that range from spanning a piece of wood across a tile and putting a hook into it to hanging a hook from a wire that goes into the wood up above the drop ceiling. I'm just looking for the "best" option.
I forgot I changed my location so it no longer said "Novi".
