AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Epson 8350 vs BenQ W6000
post #1 of 12
Hi,
I need some recommendations. I was set on the BenQ W6000 but I'm having a hard time finding it online, or anywhere else for that matter, at a good price. So now I'm looking at the Epson 8350 for my home theater.
Room:
18.5' deep
13' wide
Throw: 17-18'
Sitting: 16-17"
100% control light at night
90-95% during the day.
Movies, DirectTV, Football, PS3
I have actually found the W6000 but it's anywhere from $400-600 more then the 8350. Is the W6000 that much better or should I go for the Epson? Which would be the better projector for my settings?
Laz
post #2 of 12
Sorry, forgot to add that it will be ceiling mounted and thinking of getting 120" diagnal fix screen from Foucufix
post #3 of 12
Sorry if its about picture quality then the W6000 for sure!! dont go LCD as it lacks sharpness and pop of DLP
post #4 of 12
The W6000 will have a much brighter and sharp picture compared to the 8350. It will also have better blacks compared to the 8350. Because of the brightness, if you're susceptible to color separation (Rainbow Effect), the W6000 will have more than most DLPs. The brightness combined with a 'slower than most of what's offered today color wheel' RBE will be more prominent. That's the only thing you should be worried about. If RBE doesn't affect you, like many people, this shouldn't be a problem. The W6000 is probably a tad noisier too. But it is definitely worth the extra 3-400 dollars in price difference.
post #5 of 12
I really like the W6000, but I'm surprised how hard it is to find for a discontinued products. I did find a refurbished one at a good price but are a little hesitant with non-new products. I'll keep looking but if anybody knows of a good online store I can buy one, I would appreciate it.
post #6 of 12
The lens shift of the W6000, only allows the projector to be mounted slightly (very little) above the screen. Keep that in mind when deciding projector placement.
post #7 of 12
If you're cool with not getting a new one, Projector People has a w6000 for sale in their Demo section for $1332. It says all demo projectors are still covered by the full manufacturer's warranty, you just might want to call or email them about the hours/condition of the unit.
http://www.projectorpeople.com/proje...projectors.asp
post #8 of 12
That is a good deal above, that is what I'd do. Otherwise you could also look at the Mits hc4000, but it is not as bright.
Refurbs are generally pretty safe for a DLP projector (more than an LCD refurb IMHO), because so many LCD refurbs have bad convergence. I am not against LCD refurbs either though, just I know a few people that went through a lot of trouble with them from the forums. With refurbs, you just have a higher chance of needing to use the warranty and doing more than one exchange.
post #9 of 12
Thanks for all the feedback. I'm pretty set on the W6000 but as I was browsing around found the Benq Site had a refurbished W7000 for $1785. Is the 3D worth the extra price?
post #10 of 12
@Irlaz - I don't have any interest in 3D, but I was at Fry's yesterday where they had an LG computer monitor demo. This monitor had 3D capability and 3D glasses were right there, so I took a look. The 3D demo had fish and one large fish seemed to come out from the screen.
While waiting for w7000, I bought w6000. The refurb you mentioned looks good. I might have been too hasty in scratching off 3D.
My suggestion: go to Fry's and see what LG monitor with 3D looks like. You might like 3D when you see it.
post #11 of 12
I think some things are intriguing in 3D, but it's more of a novelty to me still, mainly because there are only glimpses of well-filmed and well-defined 3D scenes in most 3D movies. It definitely can make you feel more like you are there, but the content is so lacking for now.
post #12 of 12
Aren't the refurbs checked out and adjusted (if necessary) at an Epson facility (i.e. "the factory)? Can't they check for and correct any convergence problems?
