AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How can I take full advantage of DTS NEO:X and use all 11 channels?
How can I take full advantage of DTS NEO:X and use all 11 channels? - Page 2
post #31 of 61
Originally Posted by twells View Post
Are you sure you want to hook them up to the same amp channels? I'd try them as independent side surrounds first and see what you get out of them. Maybe something like at 110 and 70?
As I said earlier, I've already traded the center and one of the back surround channels for additional sides, which are at 50 deg and near ceiling level.
Originally Posted by sdurani View Post
There are roughly 530 7.1 BDs.
That was poorly written on my part; what I meant by 2 or 3 was that's how many 7.1 BD's I've heard so far on the 972.
Try the opening scene from Transformers 3; the first 10 seconds (Paramount logo) should let you hear your back speakers clearly. Do you mean with re-mapping activated? Turning on Trinnov room correction shouldn't lock you out of surround processing modes (unless you're doing an unusual configuration with your speakers).
Right, it doesn't.
I misunderstood the 972 control and display behavior; unbeknownst to me, when you successively press the front panel Surround button it toggles Auto Surround on and off, which, depending on source material, may make various surround modes unavailable.
Or at least seemed to; when toggled out of Auto Surround, the display momentarily says Trinnov Surround, which made me think I got Trinnov or DPL IIx etc.
Now that I've got that straightened out, Curt, riddle me this:
In my current setup with one back surround channel, what happens to the stereo back surround information when I use DPL IIx?
Do you know if Trinnov combinse them to mono, or do I need to use DD EX in order to not lose info?
Back to back surround speaker activity; Sanjay, leaving aside notable examples such as you've cited, how often do you feel the backs add significantly to the experience?
Using the last chapter of the Super Speedway BD, which has several instances of a view down the road and the car coming from behind and zooming past and forward, I just tried DPL IIx Music, DPL IIx Music, and Trinnov Music and Trinnov Cinema.
Still barely anything from the backs.
Whereas an improved front soundstage is in evidence almost all of the time.
post #32 of 61
Originally Posted by AVTrauma View Post
To clarify... The Onkyo 1009 has DTS neo:x (not the 3009 like I had previously posted)... So there is an AVR that has it, I thought I had heard/read that. Unfortunately, I'm not sure it will do full 11.x when paired with external amps, could you enlighten me?
The 1009 CANNOT do full 11-channels, even with external amplification. It only has the processing power to generate the sound for 9 channels at a time (not counting the sub). Believe me, if it could do all 11 at once, I'd be running it that way with an external amp!
So the 1009 is not a solution for the original poster who wanted full 11-channel capability.
post #33 of 61
Right now, the only real solution is the 4311 with 2 external amps, but it will only do DSX and not Neo:X. Audyssey recommends heights first, then wides, then rears if you have to reduce your setup below 11.x
post #34 of 61
Right, there are solutions for 11.1 if you want to do DSX. Both Denon 4810 and 4311 will do that with external amps. Nothing can do 11.1 NEOX tho. And iirc, Audyssey recommends wides first, then heights.
post #35 of 61
I don't understand this statement. Do you mean that rears are the first to go if you have to use less than 11 speakers - or last to go? Just curious, really. I'm wired for all 11 speakers.
post #36 of 61
Audyssey recommends the following surround format priority:
7.1A= 5.1 + W
7.1B= 5.1 + H
9.1A= 5.1 + W + H
9.1B= 5.1 + W + R
9.1C= 5.1 + H + R
11.1A= 5.1 + W + H + R
http://www.audyssey.com/audio-technology/audyssey-dsx
post #37 of 61
You setup your normal 5.1, then the others are added in this order:
7.x - Front Wides
9.x - Front Wides and Front Heights
11.x - Front Heights and Front Wides and Rear Surrounds.
My room is too narry for front wides, so I am doing a 9.x with front heights and rear surrounds.
post #38 of 61
7.x - Front Heights
9.x - Front Heights and Front Wides
Ummmm wrong.. See my post above with link to audyssey website. They recommend wides before heights, then rears are last.
post #39 of 61
Originally Posted by mbrennem View Post
I have an 11.2 setup but my AVR (Onkyo 1009) can only drive 9 at one time. I run heights+wides for 5.1 content and wides+rears for discrete 7.1 content.
I really love the wides, they expand the front soundstage dramatically.
BTW I prefer DSX to Neo:X
This is really good to hear! I run 9.2 from a 3007 using wides.
I love DSX-Wide and you comment has given me fodder to
wait for more features than the current batch of high end AVR's.
post #40 of 61
Depends on who is doing the recommending.
When going beyond 5.1, Audyssey recommends starting from where our hearing is strongest (where we can appreciate the additional imaging stability) and working your way to where our hearing is weakest. That means their order is: Wides first, then Heights, finally Rears. So if you have 9 speakers, their recommendation would have a full 7 of them in front of you with only 2 speakers to describe the entire surround field. A little lop-sided in my opinion, but that's just me.
Pretty much everyone else (including the movie industry) has gone the opposite way, starting where our hearing is weakest (where we need the additional imaging stability) and working to where our hearing is strongest. That order would be: Rears first, then Heights, finally wides (if at all). The movie industry has been doing this by keeping the front channels at 3, but adding more channels to the surround field over the years: Dolby Stereo (mono surround channel), 5.1 (two surround channels), Surround EX (three surround channels), 7.1 (four surround channels).
So it depends on the approach that makes sense to you. Personally, I'd rather put additional speakers/channels where our hearing is weakest, for the same reasons we give crutches to people with weak legs or prescribe glasses to people with weak vision. When expanding beyond 5.1, I would (did) start with Rears, would then add Heights, and then possibly wides (though I personally don't see much need for those). YMMV.
post #41 of 61
Personally, I want it all lol.. But seriously, thats the exact reason I want to be able to have an AVR that can process all 11 channels so I wont have to feel like I am making any compromises. And I want the ability to decide for myself which additional channels I prefer, and which mixing matrixes I prefer as well. If there are no 11 channel NEOx AVRs by the time I buy, it will be a real hard time for me deciding on if I want to go with a 9 channel AVR with both NEOx and DSX like onkyo then determine which extra channels I like best; OR get an 11 channel capable unit like Denon but not have NEOx. Either way is a compromise. And at that point, price does become a factor, so I think would most likely go with an Onkyo and still set up all 11 speakers, but only use 9 simultaneously...
Ugh, I hate trying to make a decision where the ultimate desired outcome is not achievable no matter which route is taken.
post #42 of 61
You need the new Dolby Atmos 11 channels are old news lol. http://www.engadget.com/2012/04/26/d...urround-sound/
post #43 of 61
Wow! 64 speakers huh!? Should I use dipoles on all the back half of the speaker array?
post #44 of 61
I could imagine some really cool suspense from above effects with one or two strategically placed center ceiling speakers. One above the main center and one above the seating area, maybe even another to the rear.
post #45 of 61
And Dolby Atmos is not the only new "better theatrical sound" technology designed to attract consumers into choosing one particular movie and|or theater in preference to another, viz:
Originally Posted by SoundChex View Post
As only an observer mostly trying to infer the longer term impact [of Dolby Atmos] on Home Theater, I was interested to read this 5/8/2012 screendigest article "Cinema sound becomes a competitive environment again" (link). It seems to suggest there is (about to be) more of an "audio oriented" struggle for the hearts, minds, ears, and wallets of the high street movie-going public than I had heretofore believed . . . and that we might soon expect to be making our movie and|or theater choices by considering the availability of Dolby Atmos, [imm sound (RIP - eaten by Dolby 7/2012),] Iosono, Auro 11.1, and Illusonic 3D sound as an additional characteristic.
[I have to wonder just how capable is the average theater goer to make a critical discrimination between these five 'enhanced sound' technologies...?! ]
Of course it remains to be seen (1) just how successful will each of these products be in the theater, and (2) when--and to what extent--will any movie theater success translate into the Home Theater environment...?!
Edited by SoundChex - 7/25/12 at 4:00pm
post #46 of 61
You are right, I mixed it up. I will correct my post.
post #47 of 61
Room width on its own is not a factor; just put the wides on the side walls at the proper angular location.
post #48 of 61
I guess right now there is only one AVR in the horizon that can do 11.x DSX and Neo:X
The Denon AVR4520 is supposed to be the replacement for the 4810 and 4311.
Here's hoping that Onkyo's 5510 (5509 replacement) can do that too.
With the change the DenonLinkHD, I might also just bin my DenonLink4 combo of 4010 Universal+AVR4810 and just go for the Onkyo. I already have 11 channels of external amplification and I would love to go full balanced.
post #49 of 61
Originally Posted by noah katz View Post
The above doesn't apply if you have Logic 7, which I found to make effective use of the back speakers.
I have found this to be true. When I listen to TV programs with surround sound, I swear if I decode using Logic 7 the room comes alive. Go back to Dolby Digital and it is, well, meh. It is like the sound engineers did the spicing up with Matrix surround, but did very little with discrete. The embedded surround from the front channels does leave the Dolby Digital track in the dust on some programs. This isn't always true, but there have been times I was so glad to have the Logic 7 decoding ability.
post #50 of 61
post #51 of 61
Originally Posted by mike kaw View Post
i think the new yamaha RX-A3020 can be expanded to 11.2
http://usa.yamaha.com/products/audio-visual/aventage/?selected=384538_384537_&mode=compare
From the spec sheet it looks like it implements NEITHER DTS Neo X nor Audyssey DSX
From the rear panel, it looks like it offers the following pre outs
Regular 7.x (up to .2 subwoofer for front and rear)
Front Presence x2 (in place of Zone 2)
Rear Presence x 2 (in place of Zone 3)
For 11 channels in total
But I am not convinced of Yamaha's presence speakers having owned an old Yamaha 2700 in the past. And wasn't too impressed with it. In fact, most reviews of DSX and IIz always tell owners not to be put off by a bad experience with Yamaha's presence speakers because DSX/IIz do improve the soundstage and was not at all gimmicky. This was borne out with my own experience as well.
post #52 of 61
post #53 of 61
post #54 of 61
Right... But at least the technology is out now. Maybe Ill wait to see if the new Denon is at any better of a price point.. But then, at that point, the debate becomes whether or not having NEO X is worth the extra $1000 over just having 11 channel DSX thats available from the Denon 4311.. Of course there are other new features you get with the extra grand, but its still a good chunk of change!
post #55 of 61
Hopefully we will see a pre/pro with full DTS NEOX 11.4 Marantz would be nice but I am not holding my breath frown.gif
post #56 of 61
Interestingly, I don't recall hearing about how much impact (if any!) the acquisition of SRS patent technologies has had|will have on DTS Neo:X evolution over the next few years...?! From what I read 'now', it would seem the 'integration' of DTS|SRS is 'mostly complete' so perhaps we'll see some results of that union soon...
post #57 of 61
Audio 11.4 / ch laid low with the like of me.
post #58 of 61
This is what I am talking about Multi-Dimensional Audio :)
http://www.srstechnologies.com/landing.aspx?id=2459
http://www.twice.com/magazine/homeaudio/dts-outlines-plan-promote-mda-surround-sound/104706
http://www.soundandvisionmag.com/blog/2012/05/16/3d-audio-update-srs
http://www.hometheater.com/content/tech-spotlight-srs-future-surround
Interesting Paper
http://www.linkwitzlab.com/multidimensionalaudio.pdf
post #59 of 61
e,
Thanks for the links, though I don't see how the last one fits in
post #60 of 61
Wups, someone read past the title.
