AVS › AVS Forum › A/V Control & Automation › Home Automation › Panasonic plasma ST50 or ST30 IP control protocol?
post #1 of 2
Hi,
I just ordered a Panasonic plasma (TC-P60ST50) and would like the IP control protocol to control the set as I don't want to use a Global Cache WIFI2IR.
I haven't received the TC-P60ST50 yet, but I'm pretty sure it doesn't have the 3.5mm service port like the VT30 did so I can't use this document:
http://files.remotecentral.com/downl...era3d.zip.html
I share all of my work, so if someone helps me find the ip control protocol, I'll post the driver for download once it's complete at this location:
http://cocoontech.com/forums/forum/5...-home-control/
Of course, if it's a proprietary protocol and you don't want me to share it, I won't. In this case, feel free to PM me
I found this that seems to work for several of the Panasonic bluray players:
http://www.avsforum.com/avs-vb/showp...postcount=6256
It also looks like there is an android app called Viera Remote made by Panasonic. Has anyone packet sniffed and reversed engineered its protocol?
post #2 of 2
I can't help unfortunatley, but I have a similar request for an LG TV.
While it has RS232, it would be easier to just use the one Ethernet connection for both control and data.
Mick
  Back to Forum: Home Automation
