So, I want to make it much easier for folks who haven't a clue on what things should cost and take the guess-work out of much or even all the system design & selection.
To do this, instead of doing what all us idiots do in the industry; talk to other professionals and hear their thoughts; I figured I'd like to mix it up and ask... uh... I dunno... the people we build and sell systems to
1) Specific to DoItYourself crowd; do you do things yourself because:
a. You're scared that your being Sold what your local guy wants to sell... not what you actually need
b. You don't see the value professional designers/installers bring to your project
c. You don't like that the professionals always have to "get back to you in a week" with a spec & price
d. You're just a cheap-ass and will always buy things in pieces and parts if it means saving a buck... regardless of not having a professional you can talk to when there is a problem.
2) If you had the option to purchase a complete system, that you could do yourself which had excellent professional support you can call on/in if needed (so you don't necessarily have to run to AVS forum with questions) , do you see enough value in buying from a company to avoid piecing it together... even if it means your paying more than you would trying to piece it together from unauthorized internet sales companies?
3) If you had the option to purchase a complete system; that you could do yourself or have professionally installed; would you rather see it priced as installed with uninstalled as an option or have it priced as uninstalled with installation as the option?
4) If you could design your own systems with a professional (systems... not pick out a single component), do it on the fly, and make changes to the design on the fly and come to a solution which fits your needs as well as a budget you can live with, would you rather have the initial system design presented as:
a. The right solution (both in terms of performance & installation requirements) with the ability to easily make changes to options which will bring the cost down
b. A bare-bones; least expensive solution which meets your needs and then add on the options which will enhance performance and installation.
Here's an example...
At the end of the needs analysis, we determine you need a 5.1 surround sound system with better-than-average wall-mounted speakers and you have a cabinet which will be placed under your TV. Because of the room & requirements for the system good balance between performance and cosmetic appeal, we kinda of know you're going to want wall-mounted TV and decent performing in-wall speakers... So
Should I go with what I know you ultimately want (wall-mounted TV & in-wall speakers)... and then let you take the wall-mount out and go from in-wall to on-wall speakers as a way to bring the cost down?
OR
Should I figure the TV will use it's included table-mount and the speakers should be the cheapest thing we offer... and then let you add in a wall mount and upgrade to more attractive/better performing speakers?
I greatly appreciate all of your feedback.
OR
