Originally Posted by MrFishcake
Thank you so much for this. this sort of answer is exactly what I needed. I had no idea what the reference levels meant.
And when i said about the blacks being darker on low I probably meant that lighter colors were becoming darker. so on normal everything appeared lighter
I will set it to low + standard and post again after doing all my tests for the blue trailing. Might I add that TV and blu-rays look great with no issues at all on low setting. I just need to get my xbox settings right and Im sorted.
Thanks again.
EDIT: (AFTER TESTS)
Wow..., thank you so so so much. It actually worked... And now im thinking that i didn't ever need to return the eh5300 tv's in the first place.. Because changing the settings to this has completely fixed the blue trailing issue I had.
I always had it set to expanded + low. and auto colour space (on xbox) So that was probably the reason I was getting that issue. Anyway, I cant thank you enough for helping me with this, Not only has it fixed that trailing issue, but it has made motion performance much better too.
I just need to get my picture settings better now.
Thanks again.
EDIT: (AFTER TESTS)
Happy to help
