I've been playing with gamebrowser on my laptop while thinking about piecing together a HTPC.
I'm going to use it for movies (3D and 2D), music, and emulators. The most demanding task with be the emulator for ps2. I might also use the computer for ripping blurays and light video conversions (just for my samsung galaxy player 4).
I already bought the MB so hopefully it's okay.
MB:GIGABYTE GA-Z68MA-D2H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813128495
Still need:
CPU: i5 2500k (I'm not sure but I think pcsx2(ps2 emu) runs better with quad core so I pick this over the i3 2120)
GPU: Nvidia GTX560Ti
http://www.newegg.com/Product/Produc...82E16814130604
RAM:4GB DDR3 (2X2GB) Gskill ripjaws DDR3 1600
Case: Silverstone LC17
HDD: 2X 2TB (the case will hold up to 6) plus 1 64GB SSD
Optical drive: slot load bluray drive
PSU: I'm not sure, I think 750 watts should cover it even if I add up to 6HDD.
corsair
http://www.newegg.com/Product/Produc...82E16817139030
or seasonic
http://www.newegg.com/Product/Produc...82E16817151107
main concern is if the psu is big enough for everything.
Still need:
corsair
or seasonic
If the hardware you've chosen is similar to any of the recommended components (i.e., motherboards with tested chipsets, CPUs, and memory) then rational thought should tell you that it has more than a reasonable chance of working in your system.
