So I built a HTPC using a E35M1-M pro a few months ago. The main parts are
E35m1-m Pro
Silverstone case
Xonar ST + expansion
Seasonic fanless PSU
WD hard drive
From day one I have had the same problem. A switching noise that can be heard on the line out. The reason it is such a problem is that I am using very efficient speakers so every little noise is magnified in the system. Here is everything I have tried to get rid of it.
Replaced PSU - No change
Removed sound card - noise still comes through stock headphone/line out
disconnected power to HD while system is running - No change
replaced MB under warranty - just got it back and no change
I now think that this is a problem that is inherent to this motherboard. I am ready to try something else but I don't want to spend an arm and a leg considering how much I have already had to deal with. Can anyone recommend an alternative that is around the same price point, has PCI and onboard graphics good enough for 1080p?
E35m1-m Pro
Silverstone case
WD hard drive
