AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz NR1402 or Yamaha RXV471?
post #1 of 4
I'm looking to buy a receiver. I have it narrowed down to the Marantz NR1402 and the Yamaha RXV471. They're both the same price. It will probably be driving a pair of Paradigm Atoms at low volumes. My main concern is reliability and quality of FM tuner. Which receiver would you choose?
post #2 of 4
Marantz because it has Audyssey MultiEQ, better than the Yamaha 471's YPAO room calibration software.
Both brands have been pretty reliable.
What devices will you be connecting?
post #3 of 4
Mainly FM, but will also use it to connect an iPod, DVD player, and TV. I might add a HTPC in the future.
post #4 of 4
I think the differences in calibration algorithms are overblown, as long as you have an autocalibration feature you're fine.
As far as those receivers goes, unless you have a space restriction need for the slimline Marantz I'd go with the Yamaha for the extra 30 wpc. While that's only about the equivalent of one notch of "louder", I just recently returned* a 1602 and replaced it with a 671 and found the sound significantly better on the Yamaha. Obviously that's subjective, and it could have been due to circuitry, not power; but given that the two cost about the same and have prety much the same features, why not get the extra bump.
* I returned it because the DLNA on the 1602 wasn't working correctly. But I was pretty shocked and happy when the replacement receiver sounded better.
