Originally Posted by
BenJF3
This thread seems to have died fast. Any updates on this product? As a Time Warner sub I'm always looking for a complete DVR solution because what they give us is absolute trash.
I have setup and used a PC with a Ceton InfiniTV 4 cablecard tuner with XBox 360's as Media Center Extenders and I have to tell you it's just as good or better than almost all DVRs out there, MUCH cheaper per month since you only have to rent one cablecard ($2-3/month) and I found that even when I only ordered the very basic cable package, when I authorized the cablecard I ended up getting many of the digital channels, both HD and SD, for free. Of course that all depends on your provider and what they throw out there "in the clear". Easiest thing to do would be to hook your cable straight to your HDTV, if it has a QAM tuner, and do a channel scan and see what comes up.
With this setup you get a whole home DVR without the added costs and limitations of your provider's equipment (TW, Comcast, Dish, DirecTV, etc.).
It's at least worth looking into.
