Need some help from you folks-
I want to build a switched outlet rated at 30 amps (pro amp sub power) that I can turn on w/ the 120V out on the back of my receiver. There's a great thread that documents this, only the relay listed is no longer offered (at least that I can find).
http://www.avsforum.com/avs-vb/showthread.php?t=1236825
I found this relay, but I don't totally understand all of the nomenclature.
http://www.alliedelec.com/search/pro...x?SKU=70185356
If you mag up the picture, "30A 240VAC" is printed on the relay. I would assume (always frought with adventure) that 30 amps at 120V wouldn't be a problem...
Would this relay work as a substitute? If not, what would?
John
John
