AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung LN40D630M3F
Samsung LN40D630M3F
post #1 of 2
Does anyone know if the LN40D630M3F can be controled (power on/off...) via IP or via the USB port similar to RS233? As expected there isnt a serial port but I didnt know if you could use a crossover cable or USB cable and send commonds from a software?
Thanks for any and all help
post #2 of 2
Any insite at all?
