totally newbie here..
I am finishing my basement framing is done. i have chosen 2 area for HT and projector. can i have wiring ready for both place ? I just started researching and not sure if i am ready yet to make decision on what projector to HT to buy.
I will measure and post my diagram to get better idea. i have one box type area(9' X12') where i can put screen but its only around 7 feet bcoz of sump pump. if i can go over sump pump area, i can get 2-3 feet more.
i want to make room ready for HT/projector .
i am not sure what all wire will be needed . do i tell electrician to run flexible hose for wires ?
do you guys think i can buy later or i should make decision and do wiring accordingly..
basement.pdf 304.130859375k . file
