AVS › AVS Forum › Display Devices › Display Calibration › LC-60LE831U sharpe Calibration Newbie
post #1 of 2
Hi Guys, I recently purchased a LC-60LE831U sharpe. I picture looks a little weird, I was wondering if anyone could help me find some calibration settings for it? Thanks a ton!
post #2 of 2
There are many professional Calibrators on this forum that you can make an appointment with and they will come to your place and calibrate the display using highly accurate equipment and software.
If you are looking for someone to provide you setting numbers, check out the thread in the flat panel forum for your set model number.
This forum is about calibration and sharing numbers is not calibration, this thread will explain why sharing settings does not work very well.
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
