As I think most calibrations disk available today lack in-debt calibrations patterns for Gamut calibration, I decided to create one my self, the goal with this is not to create a disk for full calibration, as there is plenty of disks available for this, its only for gamut calibration.
b4.3.13 is the latest beta version of the disk in AVCHD format (This need burning to a DVD)
b4.3.13 is the latest beta version of the disk in Blu Ray format (This need burning to a BD)
b4.3.13 is the latest beta version of the disk in mp4 format (This can be used from a HTPC)
if any problems please shout up
b4.3.13 is the latest beta version of the disk in .mkv format
a5.0.0 Only contain CALMAN patterns and the basic patterns - More will follow.
Just a quick guide to what format to chose:
Use the Blu-Ray version if you wish to burn to a Blu-Ray disk (BD25 or DB50) - use this format if your blu-ray player dont support 1080p/24fps via AVCHD (reports suggest that panasonic players dont)
Use the AVCHD in when burning to a DVD but blu ray playback
fix list:
known bugs:
None
100% luminance - Saturation Sweep
75% luminance - Saturation Sweep\t\t\t\t
50% luminance - Saturation Sweep\t\t\t\t
25% luminance - Saturation Sweep\t\t\t\t
\t\t\t\t
100% Saturation - luminance Sweep\t\t\t\t
75% Saturation - luminance Sweep\t\t\t\t
50% Saturation - luminance Sweep\t\t\t\t
25% Saturation - luminance Sweep
100% luminance - 100% Saturation: Primaries/Secondaries Sweep\t
100% luminance - 75% Saturation: Primaries/Secondaries Sweep\t
100% luminance - 50% Saturation: Primaries/Secondaries Sweep\t
75% luminance - 100% Saturation: Primaries/Secondaries Sweep\t
75% luminance - 75% Saturation: Primaries/Secondaries Sweep\t
75% luminance - 50% Saturation: Primaries/Secondaries Sweep\t
50% luminance - 100% Saturation: Primaries/Secondaries Sweep\t
50% luminance - 75% Saturation: Primaries/Secondaries Sweep\t
50% luminance - 50% Saturation: Primaries/Secondaries Sweep
Grey Scale Patterns 5 & 10% steps
Clip Pattern
Color Test Patterns
Reference pictures
Future Plans:
MP4 version
Others??
attached is the xyY targets for all patterns. Big thanks to Zoyd for his big work in creating this disk.
GCD_targets_v13.xlsx 254k .xlsx file
Thanks alluringreality & dr1394 for helping with utility's to make this possible
Edited by visca blaugrana - 1/6/13 at 4:21am
fix list:
known bugs:
None
\t\t\t\t
Clip Pattern
Color Test Patterns
Reference pictures
Future Plans:
MP4 version
Others??
