Originally Posted by
fredman2005
Any news about my problem? Has anyone else burned and used successfully the Blu-Ray version?
I also had problem with the Blu-Ray version.
When I investigated the directory structure on the disc I found that the STREAM directory was empty, but all files were actually on the disc. If I remember correctly the BDMV and CERTIFICATE folders are repeated in the BDMV folder. Solution is to use only these two sub folders and recreate the disc.
(Maybe it is easier to understand what is wrong if you compare folder structure with previous version of the GCD disc)
How to build a new disc or ISO file with ImgBurn
Use “Ez-Mode Picker” and select “Write files/folders to disc” or “Create image file from files/folders” if you want an ISO file.
Drag the correct BDMV and CERTIFICATE folders into the larger window below Source.
Select Mode1/2048, UDF 2.50 under “Options” and label UDF: GCDb4_3_13 under “Labels”
Start the Build process
