AVS › AVS Forum › Display Devices › Display Calibration › GCD - Gamut Calibration Disk
GCD - Gamut Calibration Disk - Page 3
Poll Results: What format would you prefer for the HTPC?
  • 32% (11)
    .mp4
  • 67% (23)
    .mkv
  • 0% (0)
    others (please detail in thread)
34 Total Votes
post #61 of 608
Originally Posted by visca blaugrana View Post
Just did some my self and as far as I can see the Magenta 50/50 is ok (Beta 3.0) see attached this is on a Samsung LCD
I am planing on adding the following
100 Saturation - Luminance Sweep (R100%,R75%,R50%,R25% etc....)
75 Saturation - Luminance Sweep (R100%,R75%,R50%,R25% etc....)
50 Saturation - Luminance Sweep (R100%,R75%,R50%,R25% etc....)
Any other patterns needed?
when all pattern is correct and done, I will start working on the 1% APL version
I agree, the 50/50 magenta pattern is ok. I checked the new patterns against AVSHD and all are very close in xy and Y, nice job. I think the labeling of the new ones should be changed to something like:
100% luminance - 100% Saturation: Primaries/Secondaries Sweep
As far as additional patterns, now that I know my display has a kink at 50/50 magenta I'd like to have the Primaries/Secondaries at that location. So maybe add 50L/50S, 75L/50S, 100L/50S
Here are the target xyY for anyone wanting to calibrate to the 75% locations.
100% Luminance, 75% Saturation
Targets x y Y [%]
R 0.557 0.330 21.5
G 0.303 0.533 71.8
B 0.191 0.127 7.2
Y 0.393 0.462 92.1
C 0.247 0.329 79.7
M 0.319 0.197 28.1
75% Luminance, 75% Saturation
Targets x y Y [%]
R 0.558 0.330 11.3
G 0.303 0.531 37.3
B 0.191 0.128 3.9
Y 0.394 0.463 49.4
C 0.247 0.329 41.4
M 0.319 0.200 15.2
post #62 of 608
Good to hear you agree that 50/50 is good - unfortunately not so good for your TV
is the sequence as it is good for HCFR? Is the white needed at the end (for 50, 75 &100% luminance - Saturation Sweep)?
I will be adding a white in front of the 50, 75 &100% luminance - Saturation Sweep, as this is needed for ChromaPure
also I will add the requested sweeps
post #63 of 608
Very thanks for your great works !!!
post #64 of 608
I have compiled a quick list of chapters:
50% luminance - Saturation Sweep 000000
75% luminance - Saturation Sweep 000001
100% luminance - Saturation Sweep 000002
100% luminance - 100% Saturation: Primaries/Secondaries Sweep 000003
100% luminance - 75% Saturation: Primaries/Secondaries Sweep 000004
100% luminance - 50% Saturation: Primaries/Secondaries Sweep
75% luminance - 100% Saturation: Primaries/Secondaries Sweep 000005
75% luminance - 75% Saturation: Primaries/Secondaries Sweep 000006
75% luminance - 50% Saturation: Primaries/Secondaries Sweep
50% luminance - 100% Saturation: Primaries/Secondaries Sweep
50% luminance - 75% Saturation: Primaries/Secondaries Sweep
50% luminance - 50% Saturation: Primaries/Secondaries Sweep
25% Saturation - luminance Sweep
50% Saturation - luminance Sweep
75% Saturation - luminance Sweep
100% Saturation - luminance Sweep
any comments? (please ignore the numbers at the end that is purely for encoding purposes)
post #65 of 608
No comments!
Very very thanks for your great works !!!
I can not wait!
post #66 of 608
sequences are good for HCFR, you drop the final white and add to the front and HCFR users will just skip the first pattern. Chapter layout looks good.
post #67 of 608
Where 25% luminance - Saturation Sweep?
100% luminance - 25% Saturation?
75% luminance - 25% Saturation?
50% luminance - 25% Saturation?
post #68 of 608
not sure a 25% Luminance sweep is necessary (Very Hard to measure accurately - especially at 50&25% saturation). However if you would like it on I will add them
post #69 of 608
good stuff
I will start encoding over the weekend
post #70 of 608
I would very much like.
Then they had the full picture of the internal color space.
Once because it will be possible to buy himself JETI-1211 or Basic Discuss or Hubble.
post #71 of 608
Yes!
post #72 of 608
Attached is the latest beta version of what I think I will call Gamut Calibration Disk "GCD"
I have also included 2 skin pattern that I use to set the "Flesh Tone" control on my TV.
as usual please comment on anything
http://gupl.dk/678565/
post #73 of 608
The link isn't working with Chrome.
post #74 of 608
Ok, I will find another host to upload to
post #75 of 608
I'll host it if you like.
post #76 of 608
Tom,
Yes please that would be great
post #77 of 608
Where 25% luminance pattern?
Sorry just noticed
All is
post #78 of 608
You can find the 25% luminance and 25% saturation patterns under the luminance and saturation sweeps, I have not added them as primary/secondary sweeps, as this could encourage you to use them to calibrate to.
To measure how the display preform with 25% luminance use the 25% luminance sweep you will find 25% luminance for all saturation levels
post #79 of 608
Thank you very match!!!
post #80 of 608
I have updated the first post with latest link and a better description.
if any comments please let me know.
Tom,
It might be worth letting a bit more testing go by, so I dont have to bother you with uploading a new file all the time, however it would be much appreciated if you would host it for me when tested a bit more
Regards
Visca
post #81 of 608
There is a fault on the 50% white' I am encoding some new videos and will upload a new beta when done, meanwhile is there any other comments?
post #82 of 608
No
post #83 of 608
I'll do some in-depth testing with the corrected version.
I haven't gotten a tutorial written yet but here are the target values for the patterns calculated for display gamma of 2.22, 2.3, and 2.4
GCD_targets.xlsx.zip 72.9775390625k . file
post #84 of 608
thanks zoyd and visca for this great work
post #85 of 608
First Post updated with latest beta.
I have also attached the spreadsheet great work
post #86 of 608
i gotta give a quick shot out to the people that helped contribute to this....well done!
all this needs is a 10pt and 21pt grayscale in the next version and i would probably use this over the AVS disc.
again GREAT JOB!!
post #87 of 608
yes, the sequence starts with 0% saturation, it's white but at the same luminance as the color that is being swept. Do you want me to post the codes for that case?
I am racking my brain trying to figure out what this is for. The only data we need is
  • level of luminance
  • chromaticity coordinate
  • calculated dE
The correct level of luminance is determined by a % of reference white, which is a known value for all colors. This is what changes, not the luminance of the white reference. The chromaticity coordinates for these various examples of 0% white white are all the same. Finally, for dE calculations these 0% patterns aren't used at all.
So, just what are these for?
post #88 of 608
Just to make HCFR happy since it calls for this pattern in the sequence and then plots that point in three different graphs. I think it would be too confusing to users to drop it even though it contains no additional information.
post #89 of 608
again GREAT JOB!!
I think to make it a complete disk, brightness, contrast & sharpness patterns would also be required, I don't really see this as an replacement to the avs-disk, more like a supplement
post #90 of 608
good point! What i do like about yours is that your patterns seem to be about 10% window size. this is perfect for plasma. The AVS disc patterns are larger and I dont prefer them for plasma. This is just my opinion though.....
