Guys,
I will try to describe the issue:
i want to wall mount my TV. I know i have to hit the studs to do so.
Now i am facing dual challenge: Equipment considered - cheetah 32-55 inch mount.
1) can these wall mounts be put in such a way that the studs could be an offset to the total mounting (what i mean by this is that do the studs have to be an exact equal (Left and right) distance from the supposed center of the TV? like lets say a tv is 40 inch length and studs are placed 16 inch apart on the wall. can i use them in such a way that the tv is from one side 6 inch towards the left of first stud and 18 inch out the right other stud...and remaining 16 inch tv is in between the two studs.
again - like there is 6 inch of tv and then the stud so there is 16 inch of tv between studs and then another 18 inch of tv after second stud.
the only reason is that with this i can do a better looking set up on a small wall which is the only option i have to set up my system etc. Dont ask me but there is no other wall i can do this on and i am sure i cant hit the studs in such a way that the tv center and the mount center are all aligned. Thats what i mean by offset.
