I have looked at every site and forum and pretty much saw nothing but negative views about using car audio speakers for home theater. Despite what people have said, I just want to say if done properly you will get very satisfactory results. Just my opinion
Featured Stories
Car speakers in home theater!
post #2 of 32
4/19/12 at 8:12pm
They are engineered completely differently and I found out trying it myself quite a few years back. I did not have satisfactory results. Car audio speakers are designed to sound good in tight spaces, not open ones, like a living room.
Design wise, it is not possible for them to sound good in open rooms. I'd like to see some room charts to prove otherwise though.
post #3 of 32
4/20/12 at 5:16am
Maybe this is a stupid question, how do measure sound for room charts? Never done that before.
As far as design, I used Win ISD for all the enclosure dimension to give the proper output and requency response and roll off for every speaker. So i dont think its impossible. Did you do something like this or just slap them in a box. Home speakers and So called car speakers are essentially the same, the only major difference is that most of car audio is 4 ohms.
post #6 of 32
4/20/12 at 5:47am
post #8 of 32
4/27/12 at 6:27pm
Car subwoofers are designed to:
1. Make use of the automotive "cabin gain", where low frequencies are "boosted" because of the small size. T/S parameters typically shoot for an F3 in the 60Hz range for a smallish sealed enclosure.
2. Survive the abuse thrown at them by a typical user.
3. Survive the harsh automotive environment...temperature swings etc.
4. Appeal to the consumer with fancy surround shapes, dust cap logos, frames, magnet covers...etc...
Home subwoofers are designed to:
1. Make use of the living room "room gain", where low frequencies are boosted much less than a car. Typical T/S paramters shoot for an F3 of 30ish Hz. in a 60 to 90L sealed cabinet...or lower in a vented cabinet.
2. Low distortion-long excursion without the flashy graphics and plastic.
So I'd say they're not really designed the same. The only similarities would be the physical parts of the speaker itself.
post #9 of 32
4/27/12 at 6:34pm
- Jay1
- Trader Feedback: 0
- No hype needed
- offline
- 3,366 Posts. Joined 8/2002
- Select All Posts By This User
That is why I said that you need to build the enclosures properly, the speaker is only as good as the enclosure it is in. In my setup I used car speakers for all channels except the sub, because I already had a JBL powered sub to use.
Power: Dual Yamaha CP2000 PA AMPS
Yamaha EX660 powered Mixer
Pioneer VSX-520-k
Center Speaker: Dual Rockford Fosgate 6.5" 3-way
L/R Fronts, Surround Towers: Rockford Fosgate 6X9" 3-way
Attachment 244961
Attachment 244962
Attachment 244963
Attachment 244964
Attachment 244965
Pioneer VSX-520-k
Attachment 244961
Attachment 244962
Attachment 244963
Attachment 244964
Attachment 244965
post #11 of 32
4/29/12 at 12:52am
- Jay1
- No hype needed
- offline
post #12 of 32
4/29/12 at 1:24am
Did you have Larry the Cable Guy help with those?
Not to bust your bubble or anything, but for about 300 bucks, you could have got yourself Polk Audio CS2 center and 4 Monitor50 towers and had yourself a pretty decent setup. Speakers designed for car audio are just that. You are somewhat correct in that a speaker, in theory, operates on the same principle, but from a design standpoint, there are many different applications that call for a different approach to get the desired results.
I applaud your effort, but i think you would do much better if you put them back in your pickup truck and got something designed for the task at hand.
post #13 of 32
4/29/12 at 5:29am
Building an enclosure is much more than building a box to put the speaker in. The dimensions of a speaker cabinet must be in accordance with the way the crossover is designed. As someone else stated, the car speakers you're using are probably designed for an infinite baffle.
post #14 of 32
4/29/12 at 7:14am
- Bill Fitzmaurice
- offline
- 5,233 Posts. Joined 11/2009
There's no difference between car sub drivers and home sub drivers other then the enclosure designs they're put in. Many "car" brands are very well regarded by DIYers. If you're designing and building your own boxes there's no reason you cant use a car sub if it models well.
Backwards you have it. The enclosure is driver spec dependent, not the other way around. Autosound drivers tend to have high Fs and high Qts figures. They're made that way to work in small sealed boxes and large untuned enclusures because that's what will fit in a car. They trade off both broadband sensitivity and low frequency response because with short driver to listener distances and cabin gain of a car they can afford to do so. Remove them from their intended environment and those trade-offs become shortcomings.
Bottom line, a well designed autosound driver is made to work well in a 125 to 200 cubic foot listening room, a well designed stereo/HT driver in a 1000 to 3000 cubic foot room. If there was no reason to make autosound and stereo/HT drivers with different specs there would be no such thing as autosound drivers.
post #15 of 32
4/29/12 at 11:37am
- Jay1
- No hype needed
- offline
Bill, I've modeled dozens of autosound drivers, the manufactuers recommended enclosure sizes are almost never the same as the ideal enclosure based on TS parameters (check out Rockford Fosgate for example). Also, what says a driver that wants a smaller box with a steeper roll off cant be put in an alignment that nets 20hz output?
The biggest difference between auto and home drivers is looks of the drivers, plain (home) vs flashy (auto).
Here's my car subs in a small sealed box with the O-Audio 20hz filter (at LP in room)
Here's the modeled response showing max output before the boost compresses.
post #16 of 32
4/29/12 at 12:13pm
post #17 of 32
4/29/12 at 12:20pm
- Jay1
- No hype needed
- offline
Agreed. I pointed that out in post 11 after he posted pics
@nooshinjohn - Larry just might have helped me LOL! He siad GIT R DONE!, You are probable right about the polks, but man I had a lot of fun putting this together.
How is a coaxial speaker any different than a sub, they are designed to play a different frequency range right? They just use passive crossoveres instead of active crossoveres to get the desired frequency cutoff whether hi-pass or low pass. Are you talking about that or cone suspension and things like that?
I really appreciate all the posts! I didnt start this thread to really chap anybody's keaster, it was mainly one of those things were they say it cant be done, and I did it anyway lol.
post #19 of 32
4/30/12 at 9:18am
Haha yeah, Obviously a 6x9 is not going to have the frequency range of a sub by no means. Nooshinjohn, was saying that a sub and standard midrange driver are different. I am saying the principles are the same as far as designing the enclosure to fit the specs for the speaker. you are just dealing with a different frequency range response and rolloff.
post #21 of 32
4/30/12 at 3:00pm
- Bill Fitzmaurice
- offline
When you measure in-room you're measuring the room response as much as, if not more than, the speaker response. You can't draw any valid conclusions from that.
You'd be hard pressed to find any transducer engineers or professional loudspeaker designers to agree with you on that one.
post #22 of 32
4/30/12 at 3:52pm
- Jay1
- No hype needed
- offline
Yes the room response is a little ragged, but look at the basic curve. This is a 22' x 22' x 8' room. I'll stick with my measured response matching my modeled response, in addition to what my ears tell me, as proof enough that you can use a "car" sub in a home lol.
You can also check the "master sub index" thread in the DIY section for many other builds using "car" subs. I'm really surprised you are arguing this given the number of successful builds...
post #23 of 32
4/30/12 at 6:19pm
- Bill Fitzmaurice
- offline
post #24 of 32
4/30/12 at 6:24pm
- Jay1
- No hype needed
- offline
post #25 of 32
4/30/12 at 7:14pm
- AJinFLA
- Manufacturer
- offline
- 1,579 Posts. Joined 2/2006
In a sense, you are both correct. Many "car" subs do indeed have higher Fs and are designed for very small enclosures, with the idea that a cars interior will produce significant gain at LF to compensate. However, not all "car" subs fit that criteria. As you point out (and obviously Bill is unaware of), there are several that do indeed have all the (T/S) parameters necessary (including low Fs) to be used in a "home" environment.
As long as you can disguise/hide the predominantly garish looks and "bling" factor.
Now WRT to using car speakers, like coaxes and triax's, this is rarely a good idea. The (vast) majority are meant to be listened to at significant off axis (like door mount) angles or even reflected (such as rear deck mount). Thus the upper frequencies tend to be designed significantly boosted to compensate (most, not all). Listened to on axis (like with HT), they will be very bright.
...but, the EQ of typical HT AVR "room correction/calibration, etc" may attenuate this enough to make it bearable. I think.
cheers,
AJ
post #26 of 32
4/30/12 at 7:50pm
AJinFLA - As regard to being bright, I will agree with you, but once I balanced out the system with a SPL meter and backed the highs off a few db with EQ, they mellowed right out.
Maybe the equipment I have used is off the beaten path and not technically correct, but I have to ask Bill, from a loud speaker designer point of view, is what I've done really wrong in reproducing accurate sound quality.
post #28 of 32
5/1/12 at 8:41am
- Bill Fitzmaurice
- offline
I'm not the least bit unaware of that. IMO autosound drivers with specs that are suitable for a home would be compromises as far as using them in a car. The two environments are too dissimilar for a one-size fits all solution.
I don't care about what anything was DESIGNED to do, I care about what it CAN do
You can drive a screw with a hammer if you want to; a screwdriver works better. A driver specifically designed for auto use will have quite different specs than one designed for the home. It's certainly not a matter of color and frills or lack of same that differentiates the two genres. That doesn't mean it can't work in the home, just that it won't work as well as one that is designed for the home. The same applies when the shoe is on the other foot.
post #29 of 32
5/1/12 at 9:28pm
They are designed for very different environments... I love car analogies, so here we go. A Ferrari Fiorano and the Swamp Rat will get you to wherever you want to go on the street, but when you hit the Nuremburgring , which one would you choose to get the job done? Now, lets say you want to go slogging through the bayou after a hurricane... different choice, right?
All things being equal in theory, they both get the job done. Home audio speakers are designed to be strong, but light and fast enough to articulate the microdetails found within the recording. Car audio trys to bring these qualities as well, but compromises must be made due to the harsh conditions created by shock, vibration, heat, moisture and extreme cold. We cannoy forget the occasional Starbucks.
Ther different conditions that speakers are designed for call for different materials, construction techniques and crossover designs. When I worked at Magnepan(summer job before the Corps) they were working on planar magnetic drivers for car audio. 10 years and god only knows how much time spent, they still had not made one that worked for the masses. My point is that some technologies simply cannot make the leap frm the home to the car and visa versa. Just because the theory of operation is the same for conical drivers does not mean that all driverswill work or are desireable for a given task.
post #30 of 32
5/2/12 at 5:25am
- Car speakers in home theater!
Currently, there are 994 Active Users
(97 Members and 897 Guests)
Recent Discussions
- › Windows Media Center vs TiVo Premiere 31 seconds ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 1 minute ago
- › Official Panasonic VT50 owners thread 1 minute ago
- › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ 2 minutes ago
- › The Official AVS Antenna and Related Hardware Topic! 2 minutes ago
- › 2313CI, RX-V673, RX-V773 2 minutes ago
- › ~ $1,500 to spend on equipment 2 minutes ago
- › Newbie here- Please help me assemble this.. 3 minutes ago
- › Can I use this cable to connect subwoofer? (2 pair 22 AWG stranded,... 3 minutes ago
- › F8500.. OR .. ZT60 ????? 3 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
