AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer KURO 5080HD odd flashing blue LED - No Picture???
post #1 of 3
Ok, for the second time in a week while watching my Pioneer 5080HD, it has clicked as if turning it on or off and the blue LED begins flashing with no picture. Cable box is still on, tv is still on but the blue LED won't stop flashing. I have to power everything off and back on and the picture comes back.
Anyone know what the blue flashing LED means? It's working fine at the moment but I am a little concerned now that this is twice in a week and it hasn't done it the prior 4 years of ownership.
post #2 of 3
Did you ever get an answer to your problem ? Because I have a similar-aged Kuro that has just developed the same problem. I'm so bummed ...
post #3 of 3
I had the same problem a few years back, mine was with the OTA,. It's getting a bad signal, contact Pioneer there is a firmware update they will send you that will rectify this. I sent for it, fixed mine and 2 friends, good luck.
