Originally Posted by
petew
Just a hair over 4.1 cubic ft without accounting for the space taken by the driver. I modeled it with WinISD and came up with 3.5 ft^3 as about optimum, considering the power I'm throwing at them. Using actual volume, WinISD says xMax at 25hz (assuming 84300 Pa air pressure in Albuquerque).
Very cool. They looked significantly smaller with the driver situated in them, and not a cube from the photo perspectives, so I was thinking it was 20x20x15. I'm glad I was totally off.
With that high frequency of an xmax at full tilt, are you planning on applying a HPF in the 20s? What's your objective, response and extension-wise?
