AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic UT50 Series Discussion Thread
Official Panasonic UT50 Series Discussion Thread - Page 5
post #121 of 2462
Originally Posted by pakotlar View Post
Very positive review, but the lack of performance summary, including mll is disconcerting. The calibration software summary report doesn't include mll, just gamma and color tracking, also doesn't mention what setting was used as far as I saw on a quick skim, although I am assuming Cinema.
The performance summary is now there, including mll. They tested the UT50 at .0037, whereas they tested the ST50 at .005.
post #122 of 2462
D-Nice measured the 50ST50's Black Level and reported 0.0028fL.
post #123 of 2462
Originally Posted by weid5 View Post
Here is a question for everyone who owns the UT50: is it normal to have motion jitter in vertical lines? For example, panning side to side causes things like light posts to be distracting - not blurry, but jittery. The same with people quickly moving side to side. I'm trying to figure out if some level of this is normal or if there is a setting to improve it. I played Witt the obvious settings and nothing seems to improve this. Is it source or content-dependent? I thought the fast refresh rate would eliminate this.
I moved up from a 40" to the 50UT50 and wonder if part of my observations are related to not being used to the larger size.
By the way, I sit about 8' from the set and most content is HD through TiVo or DVD/HD through AppleTV. In both cases, the HDMI runs through a receiver (Sony dts 810).
The TV is spectacular aside from this and I can live with it as is, but wonder if it is the norm for this or all larger TVs. Or, alternatively, if a calibration could improve it.
I appreciate any thoughts you have.
Try setting your motion smoother to off if you haven't already done so under advanced settings.
post #124 of 2462
By that logic D-Nice would report a lower reading for the UT50. Let's not compare apples to oranges.
post #125 of 2462
What's strange is that in the CNET article, they claim the ST50 and e8000 plasmas appeared slightly darker in a dark room compared to the UT50, yet their data of mll fully contradicts this. I wonder what their thoughts are on this.
post #126 of 2462
The point is that how can they state that the UT50's black levels don't go as deep as the ST50, yet their black level test results for the UT50 are so much lower than their own ST50 results? Something isn't equitable with their testing or their results.
post #127 of 2462
@PathofNeo
Did you decide if you are going with the 55 or 60 yet? Have you had a chance to try out 3d?
post #128 of 2462
I'm going with the 55" and the glasses haven't arrived yet. I'll update when it's all setup.
post #129 of 2462
Thanks for the help, PathofNeo and Mantiz. I'll play around with the settings some more. Your comment about cables is interesting. Could that make a difference? My cables are not new, but they weren't cheap either. I may try to direct-connect a source to see if it makes a difference bypassing the receiver. It seems odd to me that all sources, even the XBox have similar judder, though with variation across material as you said.
All of this being said, I watched a movie tonight on AppleTV with Motion Smoothing set to Medium and it looked quite good. I get what you are saying about different success levels across various sources.
Thanks again for the thoughts.
post #130 of 2462
Originally Posted by Sonyboy View Post
@PathofNeo
I hope you're not buying this pdp for the 3d.......It's well known that this year's line-up, across the board, have more crosstalk than even last year's line-up.
post #131 of 2462
Nah! I really don't care for 3d, but I would try some ps3 games in 3d just to see what I think.
post #132 of 2462
can the 3d be improved with a future firmware update?
post #133 of 2462
From what I've seen on the ST50, 3D looks great. I thought 3D on last year's models looked great too (my friend has an ST30). Perhaps I just haven't seen enough "good" 3D, but I guess I'll see for sure when my VT50 arrives next week...
post #134 of 2462
Amazon warehouse is currently selling the TCP42UT50 for $645.76.
post #135 of 2462
Calibration Results for a Dark Room
RGB Range - Auto
Content type - Graphics (probably the most important setting to change, colors too saturated left OFF/Auto)
Absolutely. Content Type = Graphics turns off a ton of processing on all modes. Custom becomes much more like Cinema except brighter.
Code:
I calibrated my friend's 42UT50 with these settings:
Warm Default    Calibrated Change
R-Cut   80      88      +8
G-Cut   80      80      0
B-Cut   80      7A      -6
R-Drv   ED      EC      -1
G-Drv   FF      FF      0
B-Drv   80      90      +16
HDMI Content    Graphics
Custom
Contrast                95
Brightness      50
Color           47
Tint            0
Sharpness       25
Color Temp      Warm2
*** HDMI Content Type = Graphics (This is required)
It looked vrey good and much brighter than Cimena mode.
- Rich
post #136 of 2462
But I do not understand what good used means I read it somewhere before and I assume that it could be really scratched up ?.......
post #137 of 2462
They usually have a brief description of the item at the bottom of the listing. You have to click on read more I believe and it gives you a summary. I don't believe these warehouse items come with the manufactures warranty either. They always suggest you buy a squaretrade warranty.
post #138 of 2462
Those are used TVs, not new. Avoid.
Pauls TV still has some 42 inchers left, currently going for about $719. It's a shame that this TV is discontinued, we'll never see another 42" 1080p Plasma again.
post #139 of 2462
Pauls is a good deal, however, if something is wrong with the TV right out the box(less damage) you have to wait to get it fixed. I do not like the idea that you can not send it back to Pauls. Or you can but you have to pay the shipping back from what I understand or that applies if you do not want it I guess.
post #140 of 2462
I've talked to a rep via phone @ Paul's tv, as I am looking at getting the 42 for my bedroom and asked them about returns. They told me if you notice a defect with the tv, you need to contact them within the first week and they can authorize a return or swap. If you wait beyond that or a problem appears within a few weeks or so you might have to go through panasonic. They should cover the shipping if it's within that first week.
post #141 of 2462
Actually Paul's will exchange the TV if it goes defective soon after you get it, and they'll cover shipping both ways.
post #142 of 2462
Your SM changes were confusing for a moment until i realized the columns weren't lining up.
Did you measure MML?
R-Cut 80 88 8
G-Cut 80 80 0
B-Cut 80 7A -6
R-Drv ED EC -1
G-Drv FF FF 0
B-Drv 80 90 16
HDMI Content
Custom
Contrast 95
Brightness 50
Color 47
Tint 0
Sharpness 25
Color Temp Warm2
- Rich
post #143 of 2462
From memory .005.
- Rich
post #144 of 2462
Cnet measured the blacks at .0032
post #145 of 2462
From my experience the 3d has been pretty nice. I don't get much crosstalk at all if any. I can adjust the 3d effect from 0 to -3 or +3 and make it fairly noticeable but it still isn't all that distracting.
post #146 of 2462
I'm now the proud owner of 50 inch UT50 and love it. I have a question. When playing games on my PS3, what are the advantages of using Game mode? I'm guessing it's a framerate issue.
post #147 of 2462
The difference between .005 and .0037 is practically indiscernible. In addition, any light put off by the other 4-5 sets they were comparing with would have soaked in rather well into the UT50s mono filtered glass raising it's perceived black. Everyone forgets that half of the battle with the plasma black levels is won by the filters disguising the grey plasma glass. The louver filter works in this way just as the Kuro's glass worked before that. In a dark room my S30 looks as dark (if not darker) than the St30 or Gt30-- as soon as ANY light is introduced that story changes.
post #148 of 2462
Originally Posted by QuiGonJosh View Post
I'm not the proud owner of 50 inch UT50 and love it. I have a question. When playing games on my PS3, what are the advantages of using Game mode? I'm guessing it's a framerate issue.
It's a latency issue.
post #149 of 2462
I just can not believe how amazingly deep and rich the black levels are on this TV. Loving it.
post #150 of 2462
What does it correct exactly?
