AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic UT50 Series Discussion Thread
Official Panasonic UT50 Series Discussion Thread - Page 62
post #1831 of 2462
Originally Posted by chunon View Post
So the implication is that a UT50 = VT50 ? Don't think so
Nope, just that the UT50 is not necessarily inferior to the VT50. The VT50 has a lot of juice in terms of features and picture control, but I don't think someone would sell "a better TV" for a "worse TV" in a situation like this.
post #1832 of 2462
Originally Posted by PathofNeo View Post
I won't argue technical lab specs but viewing real world content the UT50 has more punch to the picture than the VT50 IMO. Less contrast, but also sans the louvre filter so it makes up the difference
I don't test or watch tvs during daylight so I have no room to talk here (the UT would probably lose bad in this challenge).
My UT50 is worse with daylight glare than my 10 year-old EDTV Panasonic plasma. I wish this wasn't the case, but I've got windows and tons of other ambient light in my viewing area.
I'm still within my 30-day return window, and will give it one more weekend to see if I can tolerate the daylight glare. I'm leaning toward giving up the punch and bang-for-the-buck ability of the UT50 for the glare control of an ST50.
post #1833 of 2462
I don't get the bright room issue in general. It's not like roll down blinds and/or black out curtains are new inventions.
post #1834 of 2462
Amazon.com has some of the best and affordable black out curtains. I like the navy blue ones. My house looks like midnight when they're all drawn, light can't get in and can only rarely be seen trying to poke through the curtain. I can't recommend them enough if you need light control.
post #1835 of 2462
Originally Posted by tjernie View Post
Has the UT50 been tested for input lag with Leo Bodnar's Lag Tester?
I know the ST50 has ~39-42 ms and the U50 has around 27 ms. Both with game mode on.
Can any one please confirm the measured lag on the UT50 with Leo's Tester?
Thanks a million!
Please! I've searched for quite a while and can't find this info.
Can any one help? I'm about to pull the trigger. It's either a 55" UT50 or a 60" U50.
post #1836 of 2462
The UT shares the same panel as the ST/GT/VT, or at least most of the same tech. The U has a different panel, which would explain the input lag discrepancy.
At any rate, go for the extra 5". 55" to 60" is a bigger jump than most people appreciate on paper or in the store. The only serious performance drawbacks of the U compared to the UT, at least according to Cnet, is the U's inability to handle 24p input properly and the fact it seems to wash out quicker in ambient light; however, 24p input is easily defeated on any output device and I'm assuming ambient light isn't a problem if you were already considering the UT.
Edited by Yukon Trooper - 1/19/13 at 1:15am
post #1837 of 2462
I just decided that this is the tv for me. I wanted to ask for some advice about purchasing this tv. I see that amazon just sold out after having a great price. Should I wait for a bit and see if they get a few more at that price, or is the 699 price still good enough to jump on? I was thinking that if the new versions come out soon, the ut50 might get scarce.
Thanks for any advice!
post #1838 of 2462
Yep, for me my condo has a sliding glass door to the balcony about 8 feet tot the left of the TV. It has a roll down shade on it that pretty much blacks out the room.
Light control shouldn't be an expensive issue unless you have sky lights, or the whole apartment is glass like some corner units across from my place (the corners of the building are literally all huge windows. Otherwise some relatively cheap shades or curtains will give you control of lighting. And that's really needed for any display. Some are worse than others, but every type of TV looks best in a relatively dark room.
post #1839 of 2462
In the end its all subjective anyway, just from my experience there are certain problems you can't overcome without all the available controls. That's if you are looking for reference quality of course.
Edited by chunon - 1/19/13 at 8:37am
post #1840 of 2462
Before I confuse newcomers.. when I say "sans the louvre filter" I mean just that. The UT50 lacks the anti-reflective 'louvre filter' that makes the ST-up models a more appealing choice with light present. I never really bought into it since my VT50 wasn't that hot in a bright room either. There are still reflections on the ST/VT models and they both wash out in bright rooms compared to LCDs so I never understood the hype behind these so-called filters. It's true that it deflects light coming from above.. but damn what a cost in PQ to block that overhead light. I described early in the thread that the louvre filter is like some vasoline substance smeared across the screen unless your front and center (looking dead on). But as soon as you move just slightly up or down I can see the picture dim and it reminds me of the problems DLP had. This is 2013 and we shouldn't have to suffer like this. Playing the Wii and Kinect is almost out of the question unless the display is mounted high.
But that isn't the real (or only) reason why I condemn it. It fails for me because it takes away some valuable contrast that the ST/GT/VT series have. What good is better contrast ratio if you slap an aggressive filter on these 'high contrast' models that dim or dullen the screen. Yes side by side my UT50 was actually brighter in a dark room than the VT50 under any circumstance. Bright in a good way as It had more punch (not LCD blown out of proportion bright). Don't confuse this because I'll never own a standard or LED backlight LCD again. So in actuality the crippling (or hiding/masking) of contrast due the filter also means that blacks just didn't appear as inky as one without the filter. So even though the UT50 has less contrast (or technical jargon they shove down your throat) it doesn't matter because the anamorphic bars for instance have more PUNCH. How on Earth do anamorphic bars have punch? I don't know but they just seem deep like an abyss on my UT50. The blacks in demanding scenes have more PUNCH. The picture is not only punchier but cleaner. So this raw unadulterated punch from the lack of aggressive filters means that even a lowly UT50 makes films like The Dark Knight and Sin City wet your pants. I'm not saying the VT50 and Kuro won't either.. but IMO UT50 is the current king. <--- my goodness I can see the line form a mile long right now to throw a pie in my face and call me stupid lol
I think I need to youtube a 1080p vid of my Kuro next to the UT50, although the general rule is to never go by pics or vids since it's only capable of what your monitor can display.
"UT50 is the current king. <--- my goodness I can see the line form a mile long right now to throw a pie in my face and call me stupid lol"
All I have say is wow I have nothing else to say.
post #1841 of 2462
Guess no one should buy a ZT60 what a waste of cash.
post #1842 of 2462
Don't wanna hijack this thread so I'll bow out.
You don't have to bow out of this thread. Everybody's entitled to their opinion and obviously I fully express mine. I read your posts and acknowledge what you bring to the table.
post #1843 of 2462
Ya know I should have said "In a world without Kuro" so it wouldn't have upset some members and of course all IMO.
We will just have to agree to disagree I guess
post #1844 of 2462
chunon- Obviously I'm aware the VT50 can be calibrated to reference level. I'm not delusional. But it doesn't mean it looks best to my eye and there are plenty here (I get emails all the time) that praise the UT50 and the recommended settings me and anikun provide. D-Nice himself was impressed with my 42UT50 and admitted the difference in blacks in all 2012 panels were minimal and he was able to get the UT50 from 'good' to 'better' in Cinema mode. Not perfect, but acceptable enough. The VT50 is the victor if you go by numbers and numbers alone.
post #1845 of 2462
I never once implied the UT50 isn't a great set the entire 2012 line is excellent imo, both you and Aikun are providing great settings and I don't doubt the set looks great when folks apply those. Where we disagree is on the AR filter and the effect on picture quality, I see your point of view, I don't happen to share that opinion but I don't dismiss it, I know that the controls on the VT50 allow a more accurate picture, better flatter gamma and more accurate color thru the CMS. Never said one bad thing about the UT50, in fact I have defended the set many times in this thread. And 95% percent of the folks here don't need a "reference" picture to enjoy it. I routinely am amazed by my ST30 with all of its flaws. This is all subjective anyway all that really matters is that you and the other owners like their sets and are getting the most they possibly can out of them.
post #1846 of 2462
I think we have a misunderstanding. Every few years something comes along and just sets a bench in it's class. Examples from the last decade are the Sony XBR960, Sony XBR8 (tri-luminous LED), Samsung B8500 (great for local dimming LCDs), Pioneer 9/9.5G Kuro (probably the best plasma that will ever be made assuming new tech kills it within 5 years and it's not surpassed), the Sharp Elite (although I feel its priced out of range). By most.. the UT50 will never be lumped with the mentioned panels as it's considered 'low grade' and/or bargain model with 3D tacked on. It's unfortunate because I feel it deserves honorable recognition along with the best. Not only because the 50UT50, for example, can be had for $699 now but there's never been anything in it's class to perform so well. If your into Mopars then it's like the 340 was the "small block that thought it was the big block". Also I get the feeling that many within the field will disagree because they won't take the time to put their hands on it.
Anyway I'm looking forward to OLED. I think Panasonic knocked it out of the park with the 2012 models so unless there's another leap in tech then I'm content with what I have. If you want a ZT60 then by all means it's not a waste of cash. It's all eye of the beholder.
post #1847 of 2462
I would never dispute that the UT50 isn't an outstanding set for the price they are going for. In fact its an incredible bargain. The ZT60 is too rich for my blood, I will probably snag a VT50 in the next couple of months if there are any left. I definitely agree the technology leap was in last years models, we will see incremental improvements but nothing like what we saw with the 2012 models.
post #1848 of 2462
How about me and you take a breather here and start over LOL. It's all good.
edit- If your interested in the 55VT50 then Pauls has it for $1599 w/ free white glove shipping.
post #1849 of 2462
Oh I gotcha on the filter part smile.gif. Yeah some like it others don't but it's whatever works for you. If you noticed lately I'm trying not to be so abrasive as to not skew ppl. The higher end models are certainly worth the cash. So let's take a breather here start over LOL. We're lucky Panasonic gave a darn to fix/improve things the way they did last year.
post #1850 of 2462
Thats an unbelievable price unfortunatley not ready to pull the trigget thanks neo
post #1851 of 2462
Will these PlayStation 3 3D Glasses work with my p50ut50? Thanks!
http://www.amazon.com/PlayStation-3-3D-Glasses/dp/B00562O8U0/ref=lh_ni_t?ie=UTF8&psc=1
post #1852 of 2462
Just bought this tv from john lewis. Very impressed. Just wondering though how do i check the hours usage. Have been running slides and full screen content for break in period as advised but no idea how long. Any help thanks
post #1853 of 2462
The PS3 glasses will not work with the 2012 Panasonic line.
Regarding the usage hours...
Taken from JYWC55's post in the UT settings thread:
For those who are curious, here are the instructions for UT50:
1. enter the service menu (SM) - hold the Vol– button on the TV and simultaneously press INFO on the remote three times. Continue holding Vol–. The blue service menu should appear.
2. Press 2 on the TV remote.
3. Press OK on the TV remote.
4. Press the down arrow (▼) on the TV remote until you highlight “PTCT”
5. Press the right arrow (►) on the TV remote.
6. Hold MUTE on the TV remote for three seconds. That cell will display two numbers: the runtime and number of time the set has been turn on.
7. To exit, hold the Exit or Return button on the TV until the set turns off.
http://www.avsforum.com/t/1412033/the-official-panasonic-ut50-settings-issues-thread/600#post_22848982
post #1854 of 2462
anyone on the fence again should click on the buy now at amazon for the 50"
again at 599.99 and we don't know for how long, minutes, hours or a few days.
http://www.amazon.com/Panasonic-VIERA-TC-P50UT50-50-Inch-Plasma/dp/B00752VKFK/ref=cm_cr_pr_product_top
post #1855 of 2462
Thanks for the PSA! Got one!
post #1856 of 2462
And it's gone again. Glad I already got mine all set up.
post #1857 of 2462
I bought this tv just last week and I'm very impressed with it, but as its in a difficult area to get networking cable to I was wondering if anyone found a different usb dongle other than the one panasonic wants to sell me
is there a generic one that'll work with this tv, I did try the netgear wnda3100 but it doesn't seem to work with this particular set and its not listed on there site
any advice?
post #1858 of 2462
i have from an st30 might work for you pm me
post #1859 of 2462
Hello, I have been following this thread for quite a long time ... Thank you guys for putting up such a great discussion
I decided on buying 55inch UT50 based on the reviews and honestly cuz of price.. initially i wanted to buy ST50 but when I came to realize that the only difference in two is the filter and wi-fi... I changed my mind as I was planning on placing it in Dark Room with Easy Wired Connection..
I have two questions from you guys.. are there any third party 3D glassess that will work with this? I saw someone claiming Samsung glassess working but not living upto the Panny 3D glassess standard...
Secondly, I just bought a Microsoft D-3000 webcam to hook-up with the TV.. only to find out that it is not compatible... How come USB enabled WebCam's are not supported... any suggestions on how to go about it?
post #1860 of 2462
The Samsung 4100 GB glasses work great. They're flimsy compared to the Panny ones, and don't have a rechargeable battery, but the picture looks the same. I actually prefer not being rechargeable as I don't have to worry about them being dead when I want to watch something as the CR2025 batteries are cheap (like $3 a 5 pack from Amazon) so I can just keep some around to pop in whenever they die vs. having to hassle with plugging rechargeable ones into a USB port to charge.
Edited by dmaul1114 - 1/21/13 at 10:29am
